11-27-2016, 10:43 PM | #1 |
Magnito
are there articles on installing a mag in place of the dist. I have several 4 acyl. mages that could possibly be adapted to work
Hotrods don't have valve covers |
11-27-2016, 11:37 PM | #2 |
Re: Magnito
Do you know the advance curves for these magnetos? Are these possibly tractor mags?
Remember, just because something can be made to fit, isn't a good reason to make it fit. Stock ignition is so easy to fix and maintain, that I wouldn't change. |
11-28-2016, 04:44 AM | #3 |
Re: Magnito
I know of a Model A with twin ignition. Points and coil for one and magneto for the other. It has an OHV head from the 30's and quite a competition history. For ordinary running, why would you bother. Like Tom said, the standard system is soooo simple and reliable.
11-28-2016, 09:06 AM | #4 |
Re: Magnito
Most Mags put a tremendous load on the dist drive gear & shafts.
Bill Worry
11-28-2016, 01:00 PM | #5 |
Re: Magnito
I use to change tractor magnetos to dist. and use a coil. Don't go there will not help your engine. But might give you a fit. Do you know how to set the trimming, with the impulse in the mag.
11-28-2016, 01:33 PM | #6 |
Re: Magnito
11-28-2016, 02:04 PM | #7 | |
Re: Magnito
Bill W.
