06-25-2019, 05:08 PM | #1 |
1951 shoebox a chevrolet guys 1st Ford
Hi
my first ford has been fun learned a bunch. this is just going to be a fun car to take the kids and wife out in. but before i buy all the parts i just want to make sure what i am doing will work. i have a 51 that i am putting a freshly rebuilt 73 302 with a c4 with a shift kit and a 2200 stall converter. the 302 is now a 306 it should be at 9:1 now stock heads with valve spring and cleaned up ports (gasket matched & casting cleaned up.) 600 cfm holley the speedway dual plane intake. i was thinking of running the comp cams http://www.compcams.com/Company/CC/c...?csid=800&sb=2 do this its to much cam? if so what cam would you run will my hydraulic brakes work ok? thank you |
07-31-2019, 03:28 PM | #2 |
Re: 1951 shoebox a chevrolet guys 1st Ford
Head on over to the HAMB (jalopyjournal.com) and you'll get some answers. Most here on Fordbarn with a '51 Ford will be running a flathead or keeping their hood closed
07-31-2019, 04:48 PM | #3 | |
You really need to ask these questions @ COMP TECH. They will need to know how the engine is built, stall, rear end ratio and tire size along with how you want to use the car..
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
07-31-2019, 09:30 PM | #4 |
On the surface, that looks close. But K is right. Call them and ask with all the information available. Cam grinders want you to be happy, and they know more than the rest of us.
07-31-2019, 09:41 PM | #5 |
Comp Cams should be able to tell you how much manifold vacuum to expect, so you have an idea how well power brakes will work.
Sal |
08-01-2019, 08:10 AM | #6 |
08-01-2019, 09:40 AM | #7 |
I have a 302 built similar. The cam is a Comp. roller with similar specs. I also used all Comp. components. Roller lifters, pushrods, roller rockers and beehive springs. It's hyd. and revs to the moon! It's measured 9.8/1 compression. Idles good at about 800 RPM and power brakes work fine. Not bad to drive on the street. Also run 87 octane gas with no problem.
08-01-2019, 11:48 AM | #8 | |
08-01-2019, 11:54 AM | #9 |
You should also track down this book you can preview it by clicking on the sections in blue. http://www.mre-books.com/interchange/index.html I take it this is the intake you have in mind ? https://www.speedwaymotors.com/Speed...ld,394454.html "Note it is on back order" This intake is based on the older Weiand Stealth intake you can tell by the front and rear water passages which is a good thing,the newer replacement
castings have gone the cheap route and eliminated the rear passages like the newer Weiand and Edelbrock. This is the older and better version: https://www.ebay.com/itm/WEIAND-8011...4AAOSw8sZdONyE Or go this route if you are on a budget ? https://www.ebay.com/itm/fits-Ford-S...ry!85037!US!-1 Last edited by JeffB2; 08-01-2019 at 12:19 PM. |
08-01-2019, 12:13 PM | #10 |
I forgot! My heads are World windsor jr. that I reworked.
08-01-2019, 02:32 PM | #11 |
Big improvement over the stock heads. Still too much Cam for a driver. This would be a better match to your parts also read the warranty and quality difference.https://www.summitracing.com/parts/h...view/make/ford
08-01-2019, 04:00 PM | #12 |
My cam is comp. no. FS 281RF-HR10. Duration @.050 is 220, .320 lobe lift and 110 lobe separation. This is for in. and ex. Idles a little rough but smooths out real nice above idle. I do have a high stall converter, tricked out C-4 and 3:73 gears. Not hard to drive at all. It's an '88 Ford Ranger.
