Old 06-29-2021, 07:57 AM   #1
bigd1101
bigd1101's Avatar
Default touch up paint for the 53
Hi folks, is there somewhere I can find a color match for the 53 for touch up? In 53 Mercury called the salmon color, "bitter-sweet". I have the numbers from an old paint chip chart.
Don
bigd1101 is offline   Reply With Quote
Old 06-29-2021, 08:30 AM   #2
tubman
tubman's Avatar
Default Re: touch up paint for the 53
I got some touchup paint for my Corvette from an outfit called "AutomotiveTouchup.com". They have spray cans and "pens". The color matched my car perfectly.
Check out their website at "https://www.automotivetouchup.com/".
Old 06-30-2021, 12:16 PM   #3
don35
Our local Carquest store mixes paint and can match paint from a sample. They will put it in a spray can for you. I don't know about mixing from a formula. I believe the formulas are brand specific.
don35 is offline   Reply With Quote
Old 06-30-2021, 07:41 PM   #4
paul2748
paul2748's Avatar
Try a local auto paint supply store. They should be able to match it if you have a sample of the color. (take the car down to them).
My 54 is painted a later model color by the previous owner. It was a stock color off a later Suburu. I was able to get a very good match from www.paintscratch.com but I doubt they would have anything going back to a 50's color
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-30-2021, 10:37 PM   #5
o2bnkc
o2bnkc's Avatar
paul2748 has the best idea. Go to your local auto paint store. They can match it on the spot and mix it in rattle cans, pints, gallons, etc. I've been doing that for all my cars, for years.
A Proud Navy Veteran
o2bnkc is offline   Reply With Quote
Old 07-01-2021, 01:22 AM   #6
Tinker
Tinker's Avatar
Yep, but I would look at places that supply paint. Maybe do a local search for ppg distributors. Most distributors can match it and give you a spray can or whatever.
Old 07-01-2021, 07:35 PM   #7
TJ
TJ's Avatar
If you just need to touch up small rock chips etc. I did the following. I had a pin striper mix me up a small can of "One Shot" enamel to match the paint on my '40 Ford. Works great for small chips. Stripers are very good at matching paint colors.
