06-28-2021, 12:22 PM | #1 |
AC in Flatheadd 8 or 6 Shoebox
Is anyone running an AC system in your flathead shoebox? Is there enough power to run an AC system?
Steve |
06-28-2021, 12:50 PM | #2 |
Re: AC in Flatheadd 8 or 6 Shoebox
Answer is "yes". Overheating seems can be a problem. More info here.
https://www.fordbarn.com/forum/showt...r+conditioning |
06-28-2021, 04:41 PM | #3 |
I think Vintage Air has all the components including brackets for the flathead.
06-29-2021, 10:55 AM | #4 |
An alternator would likely be a better bet than a generator. Setting at long winded stop lights or other similar situations with the AC on may be a problem with the flatheads. The AC compressor has a pretty good current draw and added to the evaporator fan, an application like this may put a strain on a 35-amp system. If a person adds an electric radiator fan, it just gets worse.
07-01-2021, 06:11 AM | #5 |
I run alternators in all of my cars the 50 and Model A both. Perhaps AC not needed if I can cut the heat coming into the car.
07-01-2021, 10:04 AM | #6 |
Thread Tools | |
Display Modes | |
