Old 06-12-2022, 06:34 PM   #1
Vern
Vern's Avatar
Default Henry would be shocked...
This morning I decided to put the new shock links on the front of the roadster. Don't know what happened to the original ones; probably got lost when we re-did the front end and the brakes.
Anyway, the Ford Official Licensed Products, designed in U.S.A, had metric nuts & screws. I had grabbed a 7/16" socket and wrench, as the nut fit into the socket. But when I attempted to tighten it with the wrench, it kept slipping.
So I got a 10mm socket and wrench and everything went smoothly.
Go figure...
Vern is offline   Reply With Quote
Old 06-12-2022, 06:47 PM   #2
nkaminar
nkaminar's Avatar
Default Re: Henry would be shocked...
Two things: Where were they made? Second, you can change out the hardware. You may have to drill out the holes, or maybe not.
Old 06-12-2022, 06:52 PM   #3
Bob C
All the license means is they paid Ford to use the logo and part number, it has
nothing to do with the quality or fit of the part.
Old 06-12-2022, 07:02 PM   #4
Keith True
Keith True's Avatar
They've had metric nuts and bolts as far back as I can remember.A man with a machine shop was looking into making something for early V 8's,and when he met with the lawyer from Ford he had all nis ducks in a row.All his specs,metalurgy reports,machining plans,everything he might be asked about.The only thing Ford wanted was the signed agreement stating they were going to pay.Ford set the rate.They didn't know or care what the product was.
Keith True is offline   Reply With Quote
Old 06-13-2022, 12:01 AM   #5
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
Those are "dog bones" named as such because that is what they look like. They were never installed on Model A's. They will work with modifications as suggested but the original shock links are the tubular shock links which do not have rubber inserts like the dog bones.
The tube links are reproduced and sold by most parts suppliers. They cost more, are more tedious to install but are the correct part and last forever. with a little grease now and then.
Richard
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
Old 06-13-2022, 01:54 AM   #6
Synchro909
Synchro909's Avatar
The hardware is dumb. It doesn't know whether it's metric or imperial.
They're all nuts and bolts anyway!
More important is the quality of the bolt.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 06-13-2022, 03:26 AM   #7
mercman from oz
mercman from oz's Avatar
Nuts on Re-manufactured Parts for Early Fords made in Metric, instead of SAE - Vern
Old 06-13-2022, 05:56 AM   #8
Hotrodfil
Hotrodfil's Avatar
I've had new ones fitted with UNC bolts with metric heads, metric bolts with imperial heads, and everything in between. Normally made of some kind of cheese. I've also had the cast links crack in two.
I normally swap the bolts out for a decent quality M6 caphead anyway.
Hotrodfil is offline   Reply With Quote
