Old 07-21-2021, 08:26 AM   #21
PeteVS
PeteVS's Avatar
Default Re: 12 Volt Bosch blue coil PN-00012
Originally Posted by Crankster View Post
I've heard of Ballast resistors going bad occasionally but I don't think it's a cause for concern. Ford didn't seem to think so either (nor GM or Chrysler etc..) Remember this was THE classic points and condenser wiring circuit for millions and millions of cars and trucks, back when hollow state igntion ruled the roost.
I remember years ago seeing a car that would catch when being cranked but would cut out immediately when the starter was released. Resistor was burned out.
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 07-21-2021, 12:20 PM   #22
flatjack9
flatjack9's Avatar
That's why when a resistor needed, I use resistance wire.
Old 07-21-2021, 12:30 PM   #23
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Originally Posted by 35fordtn View Post
I've been using the black 00012 same coil just oil filled instead of epoxy..
Mike whats the resistance on the black version???
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
