04-23-2019, 12:19 PM | #1 |
48 Coupe Acelerator Return Spring
I went to install a new accelerator return spring on the firewall linkage of my 48 coupe. Slid it on and set it in the manner I thought would work, and I found the spring had no tension. What am I missing here? Does the spring have to be winded in anyway?
04-23-2019, 12:21 PM | #2 |
Re: 48 Coupe Acelerator Return Spring
Wind the spring 360 degrees to increase its tension....
04-23-2019, 12:28 PM | #3 |
Do you mind me asking where you purchased your spring?
04-23-2019, 12:36 PM | #4 |
I purchased it from Third Gen, where I buy most of my quality parts. Great service.
04-23-2019, 12:57 PM | #5 |
Geez, that'd be from us... I ask only as we got a bad batch of these springs in a while back and a few got sent off without my catching it in time.. They were not wound properly. Yours might be one of those.
Can you PM me your name so I can find you in the computer and I'll overnight a NOS spring to you. Last edited by 35fordtn; 04-23-2019 at 01:06 PM. |
04-23-2019, 12:58 PM | #6 |
04-23-2019, 03:39 PM | #7 |
Phil,
Attached is a photo of a NOS (right) and a correct reproduction (left). I have disposed of the incorrect new ones so I do not have a photo. However on the ones bent wrong, the loop or hook on the left as photographed would be bent downward instead of upward as photo’d. They are a bear to install and you do, as mentioned above have to twist them at a near 360 degrees to install. Be ready for sore fingers! I have overnighted you a replacement as we are closed the next ten days and I didn’t wish to risk you not having a correct one, even though yours I believe is the correct one after looking through sales dates. IMG_4816.jpg Sent from my iPhone using Tapatalk Last edited by 35fordtn; 04-23-2019 at 03:46 PM. |
04-23-2019, 06:04 PM | #8 |
I, for one, am very impressed by this example of excellent customer service, Kudos to you.
04-24-2019, 01:26 PM | #9 |
Thank you so much 35ford tn.
04-24-2019, 02:01 PM | #10 |
you can't go wrong with 35fordtn for parts and service.
