03-10-2014, 08:07 PM | #21 | |
Re: Pro's and Con's of relocating the spare tire?
Charlie Stephens |
03-10-2014, 08:23 PM | #22 | |
If we can come up with one to look at, I can probably duplicate them pretty easily...
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
03-10-2014, 08:35 PM | #23 |
The doors on Model As were small and with side mounts getting in and out is a challenge, but the other down side is working on the engine, you work around the wheel or take it out of the fender to do any work in the engine compartment. It is the reason my sedan does not have side mounts, even though I think they look neat and have them on my other car!
03-10-2014, 09:56 PM | #24 |
03-10-2014, 10:00 PM | #25 | |
Size matters in WV dusty |
03-10-2014, 10:11 PM | #26 |
03-10-2014, 10:18 PM | #27 | |
03-10-2014, 10:24 PM | #28 | |
03-11-2014, 12:03 AM | #29 |
I drove our Feb '29 Business coupe as a daily driver for nearly four years. All during that time I fairly frequently needed access to the STOCK trunk, and found the tire was really not in the way. During this same time, I had a picture of a '28 or '29 Business coupe that had belonged to my Dad's college room-mate. It had at least one fender mount spare on the driver's side (side pictured), and I proceeded to collect the parts necessary to eventually make the conversion. However as has been mentioned above, I came to realize that with a trunk there really was no need for the fender mount, and it actually tends to make a visually unbalanced look on a coupe!!
Mine has stayed the same as it was built. |
03-11-2014, 06:40 AM | #30 |
I have fender mounted tires on my tudor and I can't tell any difference getting in or out and working under the hood is about the same. It really makes the trunk on the back look better. It is harder to clean around the spare tires but other than that I am happy with the setup.
03-11-2014, 11:07 AM | #31 |
As Ron stated above, I don't have a problem with mine (dual sidemounts) either. The doors don't hit the tires so they don't interfere with getting in and out and how much time do you spend under the hood??
Paul in CT |
03-11-2014, 11:27 AM | #32 |
I'm in the camp for "leave it on the back" but to each their own. I think that so many were "restored" into having side mounts that the rear-mount has personality.
As for using the rumble seat, I've had a 72 year young friend hop right into there saying it was fun to re-live his childhood memories of his dad's car and he is 6'-6" tall... I've also gotten in the back just to see how it felt and I'm 6ft, 260 lbs of middle-aged cranky and did not think it was all that bad - the tire gives one more place to lean onto getting over the side. |
03-11-2014, 11:34 AM | #33 | |
also 6'4" 260 lbs it is a bit harder to get the grocerys in and out, but i would rather have it hard to grab the milk once in a while than hard to get in and out all the time tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information [email protected] |
03-11-2014, 11:52 AM | #34 |
Don't they make it in a way that you have the spare tire next to the body of the coupe and then the trunk in front of the spare tire? I swear I've seen coupes like this before.
1929 Model A Ford Coupe |
03-11-2014, 12:01 PM | #35 |
Huh! When my grandpa was putting As together he usually put dual side mounts on, except one, his personal driver that I am getting ready to aquire. It's a '31 Town Sedan with a passenger side mount. He's not around anymore and I always wondered why not that one. Now I know!
1931 Murray S/W Town Sedan Central Wisconsin Chapter MAFCA |
03-11-2014, 03:08 PM | #36 |
In the last year I have had my intake and exhaust off, my points changed and my steering box out and my spare tires have stayed in the wells. I don't think they get in way at all when working on my engine.
