Old 05-08-2023, 04:12 PM   #1
Werner
Werner's Avatar
Default Tire valve accessories
N'Abend,
who knows this tool? Are slipped over tire valves. What is the point of the devices?
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 05-08-2023, 10:55 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Tire valve accessories
Is it a tool to hold the rubber valve stem in the rim hole while mounting the tire? Otherwise, the valve stem can easily slip back inside the rim before airing up the mounted tire.
Mike Peters is offline   Reply With Quote
Old 05-09-2023, 03:06 PM   #3
Werner
Werner's Avatar
Mike,
thank you for your hint.
I don't think this is a workshop tool. It's built too fragile for that and doesn't have a good grip. The top cap is detachable.
Werner
Citroen 11 CV, 1947
Old 05-10-2023, 06:36 AM   #4
Model "A" Fords
[QUOTE=Werner;2224849]Mike,
Werner, Can you show how it looks inside the cap and where it fits in your part? In the bottom it looks like four collet fingers or grippers, are there supposed to be two more sections that might have broken off. Do the grippers have concentric groves or are they like a thread? Does the cap operate the grippers or do you turn the knurled section? Any markings other than Push/ pull?
Model "A" Fords is offline   Reply With Quote
Old 05-10-2023, 04:06 PM   #5
Werner
Werner's Avatar
The grooves of the four gripping arms are concentric.
The lid is plugged in.
When I pull on the upper sleeve, the grippers spread. If I push in, they grip tight.
There are no other markings.
I suspect that it could be a protective sleeve for the tire tube socket?
Werner
Citroen 11 CV, 1947
Old 09-23-2023, 06:55 AM   #6
Model "A" Fords
Originally Posted by Werner View Post
N'Abend,
Has anyone figured out what this object is yet?
Old 09-23-2023, 11:10 AM   #7
Bob C
Here's a link to another what is it question with no answer.
https://forums.aaca.org/topic/156255...ve-stem-cover/
Old 09-24-2023, 03:09 PM   #8
izze
I was just at the Petersen Museum
izze is offline   Reply With Quote
Old 09-24-2023, 04:52 PM   #9
mercman from oz
mercman from oz's Avatar
Columbia on display at the Petersen Automotive Museum - izze
Old 09-24-2023, 05:05 PM   #10
Model "A" Fords
Originally Posted by izze View Post
I was just at the Peterson Museum
izze, that one looks as if it is a screw on style. When I enlarge the Photograph, I don't see the top part that can be pushed or pulled. I may be missing something as it is hard to tell once enlarged big enough.
You didn't happen to remove it for a closer look? Just a knotty thought that came to mind.
Old 09-25-2023, 07:40 PM   #11
spdway1
spdway1's Avatar
Thats a dust cap, I have them on my 79-A
spdway1 is offline   Reply With Quote
