01-16-2022, 10:31 AM | #1 |
Matching numbers
I have a 1930 coupe that I bought last spring at a nearby swap meet in SC. Such a well preserved car only patch panel is in the rear tire well area. After checking closely all 3 VIN numbers match. The title, engine block and upper rail frame numbers all match. Is it safe to say I have the original engine?
01-16-2022, 10:38 AM | #2 | |
Re: Matching numbers
No one wants advice - only corroboration. -John Steinbeck |
01-16-2022, 11:23 AM | #3 |
01-16-2022, 11:53 AM | #4 |
I'd have to say yes! I have a 1930 Delux Delivery with matching numbers. It came from the Henry Ford Museum. With a Certification from Benson Research center. It was used for the Audio/visual department around campus. Have you done a background check on ownership yet?
www.whidbeymodelaclub.com |
01-16-2022, 01:45 PM | #5 | |
01-16-2022, 07:41 PM | #6 |
01-17-2022, 08:26 AM | #7 |
01-17-2022, 11:33 AM | #8 |
Gary, how would one do this? "Have you done a background check on ownership yet?"
01-17-2022, 11:51 AM | #9 |
01-17-2022, 11:57 AM | #10 | |
01-17-2022, 12:59 PM | #11 |
Yes It was in pretty rough shape mechanically, Didn't run etc. Sent email to Benson Research center.
