Old 12-06-2012, 07:00 PM   #1
billybronco1
Default Noticeable differences between a 1928 - 1929 Fordor Briggs sedan
Are there any things that stand out different between a 1928 & 1929 Fordor Briggs sedan - I'm not sure if my car is made from pieces of each and who knows what else. Vin on engine is 1928 I do not know what is on the chassis. Did Briggs mount a vin on the firewall of there body's? Is there any way to see the chassis vin without removing the body? What sudel difference could I look for to determine if it one or the other - thanks
billybronco1 is offline   Reply With Quote
Old 12-06-2012, 07:22 PM   #2
John LaVoy
John LaVoy's Avatar
Default Re: Noticeable differences between a 1928 - 1929 Fordor Briggs sedan
Briggs put their body tag on the inside in front of the seat. Many times it is missing because it was nailed to the wooden cross piece. There is no way to see the chassis vin with out removing the body.
John LaVoy is offline   Reply With Quote
Old 12-06-2012, 07:50 PM   #3
Rowdy
The 60-A in 1928 had a brown ro of and the 1929 60-B had a black roof. I know the end of 60-A and the beginning of the 60-B did not exactly corrospond with the change of the year. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 12-06-2012, 08:27 PM   #4
Terry, NJ
Terry, NJ's Avatar
I would not unscrew another bolt till I had it titled in my name. I don't know how Mass. is , but some states are notoriously difficult. I'm assuming that you don't have a title for the car? Is that right? Get it titled ASAP!
Terry
Terry, NJ is offline   Reply With Quote
Old 12-06-2012, 09:29 PM   #5
billybronco1
Yes, I have a copy of the title it calls the car 1929 but the engine vin (A43033) is found in the chart as March 1928. I know the engine could be a replacement but wondered if there where any other things to look for that would confirm the rest of the car was a 1928 or 1929 other than pulling the body to see the chassis vin
Old 12-06-2012, 10:32 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
The brake system and clutch, if they weren't changed are good indicators. Split brake shaft until November 1928 and multiplate clutch until November 1928. Also the A used a solid front motor mount until November 1928.
Old 12-06-2012, 10:58 PM   #7
Roadster62
Roadster62's Avatar
The early 1928's had a cowl vent door on one side, the only differance that I know of other than top material. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 12-06-2012, 11:44 PM   #8
Tudortomnz
Tudortomnz's Avatar
Not specific to Briggs Fabric fordors, but having either a red or black steering wheel, single bulb or Twolight headlamps, body mounted or fender mounted tailamp bracket & whether the front engine mount is bolted to crossmember or to a spring yoke, all can point to the car being made in 1928 or '29. These are some obvious differences & many earlier features got changed to later ones if bits wore out or were damaged.
Tudortomnz is offline   Reply With Quote
Old 12-07-2012, 02:25 AM   #9
JC60B
JC60B's Avatar
My 60B is stamped on the firewall with the build date (Feb13, '29). I also have a 60A body for parts and it's stamped Dec, '28 (Can't recall the exact date). The only body differences seem to be the top color, brown for the '28 and black for the '29. But one is late '28 and one is early '29. Is the build date stamping only done on Canadian cars?
JC60B is offline   Reply With Quote
Old 12-07-2012, 03:19 AM   #10
CHuDWah
CHuDWah's Avatar
It was fairly common practice "back in the day" to date the title as the year the car was sold rather than the year it was manufactured - so a 28 might be titled as a 29. Although in this case, that would have meant the car wasn't sold for at least 9 months - seems like a long time for it to sit around. I'm guessing the engine was replaced.
CHuDWah is offline   Reply With Quote
Old 12-07-2012, 06:31 AM   #11
Tom Wesenberg
Gas tanks were dated from early 28 until late 29. No one is sure, but it's thought to be the date that the tank was built and tested, rather than the date the car was assembled.
My 2-23-29 Tudor has drum taillamp but has the new 2 tooth steering box, which was just introduced in February 1929.
Old 12-07-2012, 03:37 PM   #12
1931 flamingo
1931 flamingo's Avatar
As #10 says would be my guess.
Paul in CT
Old 04-03-2023, 04:08 PM   #13
Lightman7
Also, 28 and 29 interiors are different. You can go over to Classtique's website to see the differences.
Lightman7 is offline   Reply With Quote
Old 04-06-2023, 12:20 PM   #14
ModelA29
ModelA29's Avatar
The number on the chassis will only confirm the approximate date the engine was installed in that chassis (generally a within a couple weeks for a Dearborn car to a couple months for one made at one of the assembly plants). Since there are no records you can't tell if the body that is attached to it now is the one it was born with.
ModelA29 is offline   Reply With Quote
