11-15-2017, 03:18 PM | #1 |
torque wrench
the books tell me to adjust the (differential) pinion preload to 20 inch lbs of drag. i don't have a wrench that registers inch lbs. both of mine are foot lbs. is there a way to convert it?
thanks rer_239 |
11-15-2017, 03:42 PM | #2 |
Re: torque wrench
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
11-15-2017, 04:24 PM | #3 |
Re: torque wrench
Just divide by 12.
20/12= 1.66 |
11-15-2017, 04:31 PM | #4 |
Re: torque wrench
You need to use a Inch Pound Torque Wrench as a Foot Pound Torque Wrench will not be accurate if it's a Typical 0 to 150 foot pounds.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
11-15-2017, 05:23 PM | #5 |
Re: torque wrench
i'll have to find one w/inches on it. i don't think mine will go that low.
thanks rer_239 |
11-15-2017, 06:15 PM | #6 |
Re: torque wrench
or take a long wrench and place the weight so far from the center. |
11-15-2017, 06:36 PM | #7 |
Re: torque wrench
It is easy enough to set the pre-load on the carrier and the pinion bearings by feel. Rotate each by hand; they should turn freely with some amount of stiffness. You don't want it to spin free and you don't want to have to apply tremendous hand force to turn it. It should be somewhere in the middle. Use your common sense while turning it. Does it feel close to spinning free, then tighten some more. If it is really difficult to turn looses it a bit.
You don't have to get it dead on 20 inch pounds. Anything above 14 and below 22 will be perfectly acceptable. I would not attempt to set it with a math conversion for a foot pound torque wrench. If you are going to set it with a torque wrench you need an inch pound dial indicator torque wrench that reads out the value once it is turning. In past years most people who tried to overhaul the rear axle assembly did not know about setting pre-loads. The suppliers didn't help any by providing two .010 banjo gaskets for an overhaul. People would button up the rear with the two gaskets with no thought to pre-load. In most cases they had it way too tight. Henry's 40 horses would break it loose by spinning the bearings on the mounts. That is why most that I take apart I find the bearings spun. The fact that you know and understand about pre-load is most of the battle. Set it by feel. Tom Endy |
11-15-2017, 07:06 PM | #8 |
Re: torque wrench
Harbor Freight had an inch # torque wrench a few months ago, may be still available.
May need an adapter from the wrench drive to fit. Last edited by duke36; 11-15-2017 at 07:11 PM. |
11-15-2017, 07:16 PM | #9 |
Re: torque wrench
again thanks
rer_239 |
11-15-2017, 07:42 PM | #10 |
Re: torque wrench
What Tom says. It is difficult to convey "touch" gained by experience through the written word. Like he said, the shaft should turn without too much resistance but not spin freely. I hold the shaft between thumb and forefinger for a better feel. Be aware that if the weight of the shaft is on the bearing when you test it, you will not get a good feel. I use a short dummy shaft to avoid this and one the preload is adjusted properly, the pinion bearing "pack" is put into the housing, dummy shaft removed and the proper shaft installed. (Well, that's how I do it.) With no shaft in the bearing pack and a finger poked into the tapered hole, you should still be able the turn the bearing but feel some drag.
Hope this conveys at least in part, the "feel".
11-15-2017, 07:54 PM | #11 |
Re: torque wrench
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 11-15-2017 at 07:55 PM. Reason: Correction |
11-15-2017, 08:10 PM | #12 |
Re: torque wrench
I think you can buy an inch pound wrench. Try a tool dealer.
11-16-2017, 12:03 AM | #13 |
Re: torque wrench
An engineer friend tested several inch pound torque wrenches for the RadLab. None were very accurate. I have seen the setting of pinion drag demonstrated where the banjo had all the set up in it and was spun by hand with a health pull. If it made a full revolution around the driveshaft before stopping they called it good. I did mine to spin about 1 1/2 turns as I felt the one turn might be too tight. rather a bit loose than spin a bearing. So far that is working well for me.
11-16-2017, 02:11 AM | #14 | |
Re: torque wrench
11-20-2017, 02:33 AM | #15 |
Re: torque wrench
I believe Tom also likes the 20-25 inch lbs. to rotate the carrier with bearings installed and trumpets installed. An extra spider gear holder drilled for a 3/8 bolt is then spun thru the trumpet axle hole and beam style torque wrench used. Use selected side gaskets to get this preload and pinion ring gear pattern and backlash. Shims can also be made and placed behind differential side carrier races.
11-20-2017, 05:39 AM | #16 |
Re: torque wrench
Yep, its not a good practice to try and tighten something to 1.6 #/ft.
Pre-load on differential bearings [or most] can be set by 'hand' as mentioned. |
11-20-2017, 08:18 AM | #17 |
Re: torque wrench
its kind of like adjusting a front wheal Bering. i did mine by feal
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
11-20-2017, 08:57 AM | #18 |
Re: torque wrench
I use an inch pound wrench on any torque value under 50 ftlbs,way more accurate.The value you're looking for is just enough for the bearing rollers to make contact in the races and turn,no actual preload in the text book sense.Tapered roller bearings should err to the loose side during set up by feel.
11-20-2017, 08:59 AM | #19 |
Re: torque wrench
buy one as they are cheap . if you cant find one , ill send you mine ........... steve
harbor freight !!!!!!!
V4f |
11-20-2017, 09:13 AM | #20 | |
Re: torque wrench
https://www.harborfreight.com/1-4-qu...ench-2696.html |
