Old 10-05-2010, 02:37 AM   #1
pooch
pooch's Avatar
Default 28 lower screen post screws
Are these 2 large screws on both sides lowers the same as a modern philips head?
I don't want to butcher them with an impact screwdriver with the wrong bit.
I need to remove one screw . so I can get mirror off door hinge and onto post , same as other side.
pooch is offline   Reply With Quote
Old 10-05-2010, 02:39 AM   #2
quickchange
quickchange's Avatar
Default Re: 28 lower screen post screws
Beleive they are slot screws in USA , Robinson in NZ , most parts shops carry replacement ones,
quickchange is offline   Reply With Quote
Old 10-05-2010, 05:07 AM   #3
atourer
atourer's Avatar
Pooch, they are Robertson head - nothing like phillips head, very easy to butcher up and you will NEVER get them out - suggest lots of penetrene, lots of patience & you make up a driver to put on a socket drive where you can get a bit of a turn on them - just a thought - do you really need to take them out ??
atourer is offline   Reply With Quote
Old 10-05-2010, 05:16 AM   #4
pooch
pooch's Avatar
Hmm, I was told the square slots are robertson head.
These ones I have look just like a philips head.
The rest of the car is turning up original.
Will take a pic tomorrow.
Old 10-05-2010, 01:17 PM   #5
Big John
Square head is robertson, Straight head is straight, Cross head is phillips,,,,, Some one has replaced the correct one in the past 80 yrs... a tourer is on the track,,,
Big John is offline   Reply With Quote
Old 10-06-2010, 02:23 AM   #6
dave in australia
Australian A's had slot headed screws holding the windscreen pillars to the door pillar, they were not fitted with robertsons in this location, at least on the Australian made bodies. The Canadian bodies may have had robertsons in this location. The top of the slot head screws had a slight dome on them, they are not a normal slot head. If you need come original ones, contact me. davecana@(remove)yahoo.com
dave in australia is offline   Reply With Quote
