Old 09-22-2015, 04:46 AM   #1
roddyb34
roddyb34's Avatar
Default 35 front brakes on 32-34 spindles
Just seeing if I can put 35 type front brakes on 32-34 spindles ,,,also is there a difference in 36 spindles ,,,? Thanks from Rod ,,,
roddyb34 is offline   Reply With Quote
Old 09-22-2015, 07:26 AM   #2
48-710
Default Re: 35 front brakes on 32-34 spindles
G'Day Rod,
There is a difference between '35 and '36 spindles.The spacing between the tie rod holes on the '36 LH spindle is wider by about a 1/2 inch and the spindle length is around a 1/4 of an inch shorter than the '35 one . I'm not sure about the brake bits fitting though.
48-710 is offline   Reply With Quote
Old 09-24-2015, 04:29 AM   #3
roddyb34
roddyb34's Avatar
Thanks for that ,,,I had seen that the 36 type are slightly different ,,I am after a set of 35 RHD ,,so I hope I can recognise them ,,,regards Rod,,
Old 09-24-2015, 06:09 AM   #4
tub1
tub1's Avatar
hello Rod is it the wider drums you are after?
tub1 is offline   Reply With Quote
Old 09-24-2015, 07:02 AM   #5
CT AV8
CT AV8's Avatar
Rod, you can put the '35 front brakes on '32-'34 spindles but you will need the spacer normally used for a juice brake installation.
CT AV8 is offline   Reply With Quote
Old 09-24-2015, 07:12 AM   #6
CT AV8
CT AV8's Avatar
Rod, I got mine from MT Car Products and they're called
1928-1934 Front Spindle Adapters, $20 plus shipping for the pair.
Old 09-25-2015, 05:44 AM   #7
roddyb34
roddyb34's Avatar
Thanks for the info ,,,
