Old 09-27-2022, 02:20 PM   #321
rwh
Default Re: F150 tranny with overdrive
Well folks if you have any leads on the 22t input for the "Goldilocks" transmission please let me know. Think I have everything or a path to everything I need for the build!
22T
D8UZ-7017-B
2603806
T170-16G
8-7/8" long
rwh is offline   Reply With Quote
Old 10-06-2022, 07:38 PM   #322
Hank1
I have a truck F150 transmission, drive shaft, tube and radius bars for sell asking
$2100
Hank1 is offline   Reply With Quote
Old 10-09-2022, 05:11 PM   #323
shew01
shew01's Avatar
$2100
I’m curious. Did you replace that with something better on your car? If so, what did you choose?
Old 10-16-2022, 11:27 AM   #324
abishek
$2100
Interested, if still available. PM me pics and details please!
abishek is offline   Reply With Quote
Old 12-09-2022, 09:32 PM   #325
rwh
22T
D8UZ-7017-B
2603806
T170-16G
8-7/8" long
Just looking for an input shaft. Down to the one part for the project.
Would appreciate any leads or suggestions.
Old 02-26-2023, 11:39 AM   #326
rwh
Thanks to all that have helped. Should have the OD gear from the machine shop this week and have started assembling the "Goldilocks". Sure I will have lots more questions. :-)
Old 02-26-2023, 03:36 PM   #327
shew01
shew01's Avatar
Does anyone have a lead on an output shaft for this transmission?
Old 02-26-2023, 05:29 PM   #328
Y-Blockhead
Y-Blockhead's Avatar
Thanks for the followup. Many times members ask a question and forget to let us know how it worked out. We all learn from these posts.
Old 03-01-2023, 02:58 PM   #329
Chuck McNelly
Thanks for asking the question Ray, I have been wondering the same.
Chuck
29pickup
Chuck McNelly is offline   Reply With Quote
Old 03-05-2023, 01:05 PM   #330
rwh
Bare with me folks. Trying to post a photo. Not sure this is going to work???
https://photos.app.goo.gl/GFg4XrqPFLZN66CJ7
If the picture comes through my question is about the reverse rail and what appears to be damage?
I assume that it is due the interlock pin "riding" on the shaft over time. I have disassembled two different shifters and they appear similar. It may have damaged the bore a bit.
Should I just polish the shaft to remove the slight burr I feel? Or do I need to need to do something different?
Thanks in advance for the help.
Richard
Old 04-26-2023, 08:11 PM   #331
F1_1950
I have an output shaft for the T170 for sale if you are still looking for one, etc.
F1_1950 is offline   Reply With Quote
Old 04-27-2023, 07:54 PM   #332
shew01
shew01's Avatar
Please PM me.
Old 05-30-2023, 01:32 PM   #333
ThosD
ThosD's Avatar
Originally Posted by pick View Post
Also the T5 has too low of a 1st gear and only provides over drive in the high teens vs. the Ford's 23 or 28 percnet.
Since the Mitchel trans and OD unit have lifetime waits, I have been reading old posts regarding other transmission swaps. The comments about the T5 having a too low 1st and a minimal OD ratio makes me wonder about the differential gears. Are these comments based on a 3.78 rear end? Would a 3.54 gear set improve the drivability of a T5?
ThosD is offline   Reply With Quote
Old 05-30-2023, 05:41 PM   #334
Gene F
Gene F's Avatar
Did I miss something in this thread? What about the front wishbone breaking?
Buying all of this in a kit is very appealing to me. Gosh think about it; a Burtz engine, this 5-speed (synchronized), a heavy duty radiator, and cast iron drums, and your A would be almost indistructable. The thing would basically last forever with a little maintenace here-and-there. You could run it on the freeway all day without it chewing itself up.
Old 05-30-2023, 06:21 PM   #335
Phil Brown
Phil Brown's Avatar
???? Why would the front wishbone break with the f150 trans change ?
(sorry not rereading 17 pages of posts)
Phil Brown is offline   Reply With Quote
Old 05-30-2023, 06:37 PM   #336
V8COOPMAN
V8COOPMAN's Avatar
The T5 transmissions you keep reading about with TOO LOW 1st gears is what happens when folks don't do their homework. Almost everyone HEARS that they need the Chevy S-10 T5 which will place the shifter much further forward than most other T5s. Actually, folks need ONLY the tail housing and short shifter rod from an S-10 pickup which will readily swap (bolt-on) onto something like a V8 Camaro T5 which has the close-ratio gearset. The V8 Camaro gearset has a 2.95 1st gear ... PERFECT! That 1st gear in a complete S-10 T5 is going to be either a 4.03 or a 3.76. Those two S-10 1st gear ratios are good for nothing but pulling stumps and parades!
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 05-30-2023, 06:44 PM   #337
Gene F
Gene F's Avatar
It stresses them, and they then to break.
Old 05-30-2023, 07:06 PM   #338
Phil Brown
Phil Brown's Avatar
I think theres some confusion on your part, you might be thinking of the REAR radius rods when using an open driveline. Forcing some to self-engineer ways to locate the rear axle with the now missing torque tube
The front wishbone on my 31 CCPU mounts to the bottom of the AA bellhousing just like it did when Ford made it only with the A housing.
Where is this mysterious stress coming from ?
Old 05-30-2023, 07:36 PM   #339
ThosD
ThosD's Avatar
V8COOPMAN, thank you for your reply. Your link to the T5 conversion with torque tube is quite helpful.
Old 05-31-2023, 02:16 PM   #340
Gene F
Gene F's Avatar
No. One of the guys in our club put in the open driveshaft conversion, and he skipped the front wishbone. Once on a tour, he get agressive with the throttle, and he ended up on a tow truck. Some of the companies sell a beefed-up unit.
