Old 03-11-2011, 02:21 PM   #1
blawrence
blawrence's Avatar
Default Merc Frame
I would really appreciate a little info. Do 39 merc frames fit under a 41-48 merc? What I need to know do they have the same dimensions.
blawrence is offline   Reply With Quote
Old 03-11-2011, 03:47 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Merc Frame
I don't believe they do, but maybe someone can verify that.
Old 03-11-2011, 05:40 PM   #3
oldskool
oldskool's Avatar
1939 merc has a wheelbase of 116" 1941-48 merc has a 118" wheelbase,according to a book i have...
oldskool is offline   Reply With Quote
Old 03-11-2011, 08:02 PM   #4
blawrence
blawrence's Avatar
Thanks for your help....
Old 03-11-2011, 08:12 PM   #5
Karl Wolf
Karl Wolf's Avatar
From the one example that I have seen, 1946 merc and Ford frames are the same, the front crossmember is moved forward on the Merc, there is a special part that moves the wishbone mount forward, and the steering columb is longer all by four inches, to accomodate the four inch longer wheelbase... Karl
Karl Wolf is offline   Reply With Quote
Old 03-12-2011, 07:57 AM   #6
Bob NH
Bob NH's Avatar
I can throw one point in here. A guy I used to hang out with had a 41 merc. coupe with bad front fenders so we went and picked up a set of beautys from a 41 ford and you would surely need a 4" metal stretcher to get them down over the front tires on the merc. !
Bob NH is offline   Reply With Quote
Old 03-12-2011, 05:19 PM   #7
Karl Wescott
Karl Wescott's Avatar
1942-48 Mercury will be way different than 1939-40 Merc, as mentioned the 116" vs 118" wheelbase, but also the overall shape. The 1942-48 Mercury is also different than the 1942-48 Ford because of the 118" vs 114" wheelbase. (note the basic bodys were the same 1942-48 Ford/Merc, the difference was a streched front end). I have no idea if the 1941 Merc used the same frame as the 1942-48, or if it was unique to 1941 as the Ford frame was.
I do have access to period sketches of the 1939 and 1942-48 Mercury frames, if one would help I can scan and email to you. Email to let me know karlw(at)wescottsauto(dot)com.
Karl Wescott is offline   Reply With Quote
