12-22-2020, 04:28 PM | #1 |
Does Anyone Sell 3 5/16 +.020 Pistons and Rings
Looking at the 276 50 merc motor I have had for many years and thinking of freshening it up a bit. Would like to just rebore it +.020 and get new pistons and rings.
12-22-2020, 04:45 PM | #2 |
Re: Does Anyone Sell 3 5/16 +.020 Pistons and Rings
I know Ross can make these for you. I'd assume Arias and Wisco could as well. I'd check with Egge if you don't want a forged piston. Good news about Ross (I'd assume others as well) you can upgrade to metric rings when you freshen it up.
12-22-2020, 07:09 PM | #3 |
Yes, Egge sell 3 5/16 + .020/.030 sets. Extent 3 ring street piston ay a reasonable cost.
12-23-2020, 04:54 AM | #4 |
Yes, and they weigh about 100gr lighter than the stock 3-3/16 4 ring ones.
Lawrie |
12-23-2020, 05:40 AM | #5 |
i would not buy pistons till the boring is done
12-23-2020, 08:07 AM | #6 |
Boring a block without pistons is a big mistake. Chuck if your block has been measured to be sure it will clean up with the additional .020 Then Egge as old Ron above mentioned is the way to go for the 3-5/16 +.020. Recently getting the correct size piston rings has been a problem so be sure the rings are available when ordering the pistons. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
12-23-2020, 10:41 AM | #7 |
Yes, they come with rings. This is how to get a 280 (279.4) Flathead.
Gramps |
12-24-2020, 02:20 PM | #8 |
ask any good mechines what is an eye brow. what do you do with the pistons if you have to go to 030
12-24-2020, 11:13 PM | #9 |
Tell Me, I forgot??
12-25-2020, 12:11 AM | #10 |
I 'think' what Richard is referring to is that if you bore a tapered/worn cylinder that is worn beyond the amount you've bored to, at the top of the bore will be evidenced an 'eyebrow', a potion of the bore is worn yet to a bigger diameter to what you've bored to. This should not need to occur if one carefully measures each and every bore in several places to ascertain the wear limits, and then orders replacement pistons of sufficient oversize that all cylinders will indeed clean up at that size.
12-25-2020, 09:57 AM | #11 |
you need to know what you have on all 8's find the lowest number write that down.
that number won't be perfect either. how low is that number to standard? Lets say ,010 or ,020 will clean that up. The shop will tell you first buy the pistons then it will get bored then pistons will be fitted. It will be bored just shy of your ,020 pistons then honed for piston fit.. hope this is understandable I do this, I am not John boy Walton a writer . |
12-25-2020, 10:29 AM | #12 |
Boring blocks is the most boring job you can do in the rebuilding business. In the 10 years I ran "Nostalgia engines" I probably bored over 50 blocks. Most of them were in the early years. It took about a day to do a block, then send it out to have the pistons fitted.
Gramps |
