04-28-2016, 11:58 AM | #1 |
Advice needed: 1950 F1 Parts
I'm new here, but need some advice. I'm restoring/rebuilding a 1950 Ford F1, flathead V-8. I'd like to keep it pretty much stock and use OEM parts, except for converting over to 12VDC.
1. Where would I find the best quality/priced OEM parts: steering; suspension; braking; electrical harness; etc.? 2. Is it worth adding front disc brakes, or staying stock drums? 3. I'd like to move the fuel tank outside the cab and under the bed. Any suggestions/suppliers? Thanks in advance for any/all help. Jim Nashua NH |
04-28-2016, 12:03 PM | #2 |
Re: Advice needed: 1950 F1 Parts
Little bit of conflict there, you say restore and then ask about disc brakes!!!!
The F1 brakes were popular in the 50s and 60s as a Hot Rod upgrade for earlier cars and they are what I run on the front of my 33. They are very good brakes and I would stick with them. Same goes for the steering box. If you go on some of the F1 sites they love to pull the brakes off and "upgrade" them. That's ok, but they are into modified trucks/pickups and I really don't see any reason to do it myself. Not sure if the drums are hard to come by, on my 33 I used the later model F100 drums. If you need information I can get the numbers. |
04-28-2016, 12:13 PM | #3 |
The F-1 Bendix brakes work very well, the upgrade you might want to make is a dual master cylinder (for safety). Moving the gas tank out of the cab and under the truck is not something I've considered doing to my '51 F-1 so I can't make any recommendations. I should mention that I run the OEM single master cylinder in my truck. The only problem I've encountered with the OEM brakes is fading when they get wet... Somewhat normal with drum brakes.
Imagination is more important than knowledge. |
04-28-2016, 12:13 PM | #4 |
I bought all my wiring for my 48 F-1 from Sacramento vintage ford. It was perfect, correct cloth coloring and everything fit like a glove. It will more than handle 12 volts plus their tech guy makes them and can walk you through any issues you may have.
Respecting and Resurrecting Ford Model A's. |
04-28-2016, 12:14 PM | #5 |
Thanks for the fast reply and advice JSeery. My front drums are actually in good shape, though the wheel cylinders all need to be rebuilt. I'd prefer to keep it all stock and original, but I've heard enough advice on converting over to 12VDC and getting the gas tank moved out of the cab. Finding OEM parts is my real goal.
04-28-2016, 12:30 PM | #6 |
Bob Selzan he is the best |
04-28-2016, 12:40 PM | #7 | |
Not sure I understand the concern about moving the fuel tank, seems like a a lot of effort for nothing to me, unless you are looking for space behind the seat. No safety concerns that I'm away of. You can get wheel cylinder rebuild kits or replacement wheel cylinders easily. I got some from Rock Auto, U.S. made and very good pricing. I replaced everything when I redid the brakes, springs, all hardware, adjusters, everything. Cost very little, most of the parts kits were in the several dollar range ($4 or $5 dollars, I think some were less than that!). |
04-28-2016, 12:41 PM | #8 |
Get yourself a set of parts books for the 48-56 trucks. Look up the parts, get the part numbers and use this source, www.partsvoice.com for NOS parts. If you're looking for repo stuff, then there quite a few out there, such as Mac's, C&G parts, Sacremento Vintage parts, John's F-100's, LMC truck, and more. I am restoring a 50 F-1 and I go for NOS stuff first.
As for wheel cyls, just replace them, don't rebuild. They're cheap enough. Replace all the steel lines and rubber hoses in the brakes. Safety first. If you're going the disc brake route, that is not restoring. it's modifying. Restoring means to make it as Ford built it. Too many people mis-use the word.
Barry 50 F-1 |
04-28-2016, 02:27 PM | #9 |
Contact Glenn Sanders, he is a fordbarner who specializes in F1 parts. He has a current ad on the swap meet page and he is located in the north east as well.
04-28-2016, 06:14 PM | #10 |
Welcome to the Barn Jim,all of us F-1 guys have used all the above mentioned sites for parts. All excellent sources to get yours running. And we also like pics! Ken
04-28-2016, 06:22 PM | #11 |
I've used Mac's quite often , w/good results .
04-28-2016, 10:47 PM | #12 |
Criticizing someone for trying to make his OLD FORD safer by installing better brakes. Makes me wonder what he thinks of safety belts. Restoring a vehicle to it's original form is great for those looking foe a 1000 point museum piece, instead of a good running OLD FORD as a daley driver. JMHO
04-28-2016, 11:54 PM | #13 | |
04-29-2016, 05:39 AM | #14 |
On the gas tank relocation: Before you go own this path, consider the consequences on filler tube and exhaust routing. This is a change that often becomes its own project to accommodate the down stream dislocations.
The F1 drums seem to have lost their repo source in the last couple of years. Unless a new provider has emerged, they cannot be had. A number of houses show them as catalog items but are not able to fill an actual order.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
04-29-2016, 06:08 AM | #15 |
Join the Early Ford V8 Club of New England. We have our monthly meetings in Boxboro MA and a lot of members in your area.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
04-29-2016, 07:22 AM | #16 | |
Brake Drums: Raybestos 2677R Shoes: Raybestos 228PG Wheel Cylinders: Raybestos (R) WC37083 / (L) WC37084 HW Springs: Bendix H7144 HW Adjusters: Carlson (R) H2540 / (L) H2541 |
04-29-2016, 10:23 AM | #17 |
My 51 F1 gets used as a driver, for dump runs, etc. and has stock brakes w/updated plumbing. Of course discs would ultimately be safer, however I've never experienced fade or any sense that they were unsafe. And as far as the tank goes, I've been fine with the stock location. See no particular need to move it.
04-29-2016, 10:39 AM | #18 |
There is nothing wrong with the gas tank in the cab. If your in a wreck bad enough that the tank ruptures, Your not going to be alive to worry about it. I've had mine like that for 25 years now. drive it and enjoy it
04-29-2016, 11:36 AM | #19 |
Thank you all for the advice, options, and parts places. I've heard enough now to try and keep it all stock. This truck will be an around-town grocery gitter, so the drum brakes should work fine (my drums are good enough to turn a couple of more times). The gas tank will stay put. You guys are great! I'm sure I'll be returning for more advice in the future.
04-29-2016, 11:41 AM | #20 |
Having good drums is a real plus! Should last for may years. Post some photos when you get a chance.
