10-27-2015, 12:02 PM | #1 |
F-1 steering with 40 ford steering wheel
Am building a 32 roadster and am using an F-1 box. I have a real nice 40 ford wheel that I would like to use. The F-1 steering shaft is splined but the 40 ford wheel goes on a tapered shaft with key. What is the recommended procedure. The F-1 shaft needs to be shortened anyway so why not weld on the top of an earlier shaft.
tim |
10-27-2015, 12:17 PM | #2 |
Re: F-1 steering with 40 ford steering wheel
Yep, splice in a tapered upper shaft. The only issue is good welds. In addition to the obious reason you need to keep the center hole clean and smooth for the horn wire and/or the light control selector tube and it needs to be stright.
10-27-2015, 12:26 PM | #3 |
The inside diameter of the shafts are not the same. Was thinking of using a piece of tubing and machining different OD's to match ID's of steering shafts for alignment.
Tim |
10-27-2015, 12:32 PM | #4 |
I did an F100 shaft conversion. I first tried to butt weld the shaft. I got some weld inside the tube and the horn shaft would not go thru. I then made a sleeve that pressed on and I was able to carfully position the new part and weld it up. The butt weld was dicey as you don't know the penatration. I could see the sleeve fillet welds.
Be carefull with the keyway position. Make sure you know when the box is exactly centered. The keyway in the worm would need to be straight up or down. Check it. |
10-27-2015, 01:06 PM | #5 |
The F1 shaft can be converted to taper and key without cutting and welding.
These shafts are swedged with a heavier wall thickness at the top end, so best to re-machine the top and then shorten from the bottom and press the worm back on. I do these all the time. The keyway will need to be oriented down (6 oclock position) for your 40 ford steering wheel. This will be 180* out from the keyway for the worm. Neal |
11-16-2015, 05:28 PM | #6 | |
Tim |
11-16-2015, 05:33 PM | #7 |
Neal, You definitely have come up with a great solution. Well done.
11-16-2015, 05:46 PM | #8 |
Neal, I like that approach if you have the equipment for it.
11-16-2015, 05:55 PM | #9 |
On 40 wheel it does not look as if it matters whether the key is at 12 or 6 oclock. On a banjo wheel you want one set of spokes going strait down so it matters. If I had a banjo wheel I could look.
Tim |
11-16-2015, 07:46 PM | #10 |
The horn button only goes in one way on a 40-48 wheel, so it does matter.
11-16-2015, 07:52 PM | #11 |
11-17-2015, 12:01 AM | #12 |
11-17-2015, 09:41 AM | #13 |
http://www.jalopyjournal.com/forum/t.../#post-7128615 To really appreciate Neals work read this thread on building a Hot Rod!! Pete (scroll to the top)
12-25-2023, 09:38 PM | #14 | |
Thanks for posting this info and pictures! |
12-26-2023, 02:22 AM | #15 |
5/8 x18
