04-18-2020, 12:55 PM | #1 |
Steering gear box leak 50 Merc
Not long ago I changed out my steering column/gear box for a good tight unit due to screwed up shift linkage in the column.
Before installing it in the car I washed the insides the best I could with kerosene. Then filled it with the recommended oil. Now it leaks and I have a puddle on the floor. Question is...seems I remember reading putting some sort of grease in the steering box instead of oil? What grease do I use? Probably time for a rebuild but Im not ready for that right now. i just want to drive my Merc. Be safe out there! |
04-18-2020, 01:17 PM | #2 |
Re: Steering gear box leak 50 Merc
It is common to have leaks with oil/grease. Corn Head grease is a good option.
04-18-2020, 01:21 PM | #3 |
Did you R&R the sector shaft seal next to the pitman arm while you had the box out of the car?
I hadn't touched a steering box in at least 20 years but I did the one in the truck awhile back. I've done quite a few steering boxes over the years and worked for a company that used to blueprint them back in the day. https://www.fordbarn.com/forum/showthread.php?t=264082 Last edited by 1948F-1Pickup; 04-18-2020 at 01:26 PM. |
04-18-2020, 01:46 PM | #4 | |
Available at any John Deere dealer, and even thru Amazon! Make sure to get the JD brand. DD |
04-18-2020, 03:21 PM | #5 |
Mercs from 1949 thru 51 have a truck sized sector shaft. The bushings for it are an old prewar truck part number. If the sector shaft is still pretty solid and needs no bushings, the seal will last pretty well. If the bushings are worn, it will push the lip of the seal all over the place. The seal is easy enough to replace and still easy to get so far.
A person can use the corn head gearbox grease if they don't want to mess with the sector shaft seal but eventually worn sector shaft bushings will cause other problems. |
04-18-2020, 03:35 PM | #6 |
As I seem to recall I stacked 2 seals on top of each other.
04-18-2020, 04:08 PM | #7 |
51merc-ct. Please explain stacked 2 seals?
Recall where you purchased your seals? Tks |
04-18-2020, 04:48 PM | #8 |
Not answering for him but a lot of times there's enough distance below the sector shaft bushing that you can run two seals, stacked together.
If you're putting a box together with all fresh parts, the bottom sector bushing can be easily located so that it leaves enough room for the two seals. |
04-18-2020, 04:49 PM | #9 | |
Just do a search for SKF-12334 seal, they are available from several sources. Just double check the dimensions.
04-18-2020, 05:25 PM | #10 |
51 merc-ct
Amazon has them but the only dimension listed is 2.5x2.5x0.6 inches. Sound right? How hard is it to get that old seal out after i remove the pitman arm? Any special tool? Thanks for your help and sorry for all the questions |
04-18-2020, 07:36 PM | #11 | |
The correct dim's are---- ID--- (31.75mm)--(1.250") OD---(42.82mm)--(1.687") THICK---(4.78mm)---(.188") Pry the seal out by any means at your disposal, you will figure it out.
04-18-2020, 08:57 PM | #12 |
I use this stuff in my old Fords.
https://www.youtube.com/watch?v=YYqoU9FJpog |
04-18-2020, 09:49 PM | #13 |
The dimension that Amazon gives is for the 'box' that the seal comes in.
The correct dim's are---- Dumb me.. Thanks for your help everybody |
04-19-2020, 02:26 PM | #14 | |
Seriously, who cares about what size the box is the seal comes in? Hard to believe they haven't addressed the issue. |
04-20-2020, 07:20 AM | #15 |
NO! Get the CASEIH/New Holland brand or even the Cenex labeled, just for the shock value.
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 04-20-2020 at 07:25 AM. |
04-20-2020, 12:14 PM | #16 |
X2 on the PennRite steering box lube (post #12) NO leakee.
Paul in CT |
04-20-2020, 03:09 PM | #17 |
Or cotton picker spindle grease. Same 00 as Pennrite but 1/3 the cost.
I dig coal, which provides motivation for EVs. |
