Old 11-15-2020, 07:57 PM   #1
Blastfromthepast
Default 1936 radiator petcock
My radiator petcock has a slow drip.
Has anybody taken one apart to fix the problem.
Is there a packing inside them. My valve moves to easy.
It doesn’t feel like it’s a tight fit. Thanks, Blast
Blastfromthepast is offline   Reply With Quote
Old 11-15-2020, 08:35 PM   #2
DavidG
DavidG's Avatar
Default Re: 1936 radiator petcock
If it is an original one, there's no packing inside, just a tapered fit between the shank of the handle and the base. If it is leaking and turns too easily, the tension spring on the shank opposite the handle is likely broken and needs replacement. A thorough cleaning of the base and the shank plus a new tension spring should stop the leak unless there is corrosion damage in the base or on the shank.
Old 11-15-2020, 08:40 PM   #3
VeryTangled
VeryTangled's Avatar
I'd advise caution if you are contemplating removing the petcock for inspection or service. They are brass and a gentle approach would be wise to prevent frustrating complications.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 11-15-2020, 08:48 PM   #4
alanwoodieman
I would suggest trying to remove the movable part WITH OUT removing the pet cock from the radiator, it will most likely not come off with out a fight and you could break it loose from the tank. I have used fine grit valve grinding materiel to clean the taper and then as said put on a new rear/tension spring
alanwoodieman is offline   Reply With Quote
Old 11-15-2020, 08:56 PM   #5
VeryTangled
Another note that I found out on my '35 and '36 which each had 1937 engine blocks. The cars have correct year radiators, with drains. But the later block also had drains.
Personally if I want the coolant out I'd probably go for removing a lower hose.
Plan ahead for A LOT of fluid, like 5 gal., when you do get things flowing. One normal modern radiator drain pan will not get you through the whole job.
-Jeff H
Old 11-15-2020, 11:32 PM   #6
Blastfromthepast
Thanks guys for input. Unfortunately like alanwoodieman said be carful you could break it off at the tank. Guess what, I broke it off the tank. Tried to unscrew it and just kept turning. Broke free from the tank. Any suggestions to fix it. I already tried soldiering but no good.
Maybe epoxy or to the radiator shop.
Old 11-16-2020, 05:41 AM   #7
feufeu
feufeu's Avatar
I had the same issueon my 37 radiator. wanted to replace the petcok and i broke it.
So i drilled a hole of 18mm in the radiator, and put in the hole a brass part I made. The internal of the part was threaded 1/4" NPT (like petcok). this part was soldered by radiator shop (didn't want to solder it myself...)
feufeu is offline   Reply With Quote
Old 11-16-2020, 09:06 AM   #8
Blastfromthepast
feufeu, thank you for the pictures. The brass adapter you made looks great.
I don’t know if anyone makes a brass fitting like the one you made but if the
don't you should make a few and offer them on the forum. Even a little epoxy
or sealer around it and press it in. I’ll bet it will work. Blast.
Old 11-16-2020, 12:00 PM   #9
marko39
I imagine you could solder in a 1/4 npt brass coupling which if you wanted turned down just enough to leave a small flange.
marko39 is offline   Reply With Quote
Old 11-16-2020, 11:31 PM   #10
Blastfromthepast
I’m terrible at soldering. I tried all day soldering that radiator.
I usually never surrender but today I did. Took it to a radiator repair shop.
I hope to have it back soon. Thanks guys for all your responses. Blast.
Old 11-18-2020, 02:12 AM   #11
feufeu
feufeu's Avatar
Yes it's very difficult to solder a radiator because the two boxes (top & bottom) are tin soldered, so if you heat too much the result will be leaks.
feufeu.
Old 11-18-2020, 03:26 PM   #12
G.M.
Look on Usbrassandcopper.com They have petcock valves
that look just like the original ones. G.M.
www.fordcollector.com
Old 11-19-2020, 02:10 PM   #13
KiWinUS
KiWinUS's Avatar
Delete. Sorry
Thread Tools
Display Modes
