Old 03-30-2020, 01:36 PM   #1
Ian in Mississauga
Default Gas damage on rubber
I accidentally got gasoline on my running board and didn’t notice until the next day. The rubber is now blistered or wavy. Can the damage be repaired? It’s not where it will be stepped on.
Thanks, Ian
Ian in Mississauga is offline   Reply With Quote
Old 03-30-2020, 04:06 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Gas damage on rubber
You might try some mild heat, like a heat lamp just close enough to maintain a temp in the 90's or so. Usually when I have seen rubber absorb some chemical, it tends to shrink back as it dries out.
Old 03-31-2020, 12:31 AM   #3
pbishop
You may get that 'white' discoloring look as well. In any event, after years the running-board covers will begin to crack without proper care and most likely need to be replaced. With that said, the idea of using a heat lamp sounds like a possible solution.
pbishop is offline   Reply With Quote
