#1 |
I'm replacing my rotted out angled floor panel. Can anyone tell me if there is a trick to removing the two side rivets to remove the panel? Do I need to remove the angle panel with the rear front seat riser as an assembly and then cut the rivets once I have it out? Are there any spot welds? I did find a couple on the edges where the angle panel and the seat riser meet. Thank you for any help!
If earthworms had machine guns, we'd all be in trouble! ![]() |
#2 |
Since I seemed to have stumped everyone with this question, here's what I discovered. By the way, this is on a 31 Roadster. You can access the two rivets (one on each end of the front seat rear riser) either from underneath the car or by removing the seat riser/ angle floor panel as an assembly. If you plan on replacing the curtain pan, removing the rear riser will help access the rivets that fasten the curtain pan to the cross brace.
#3 |
What stumped me was I couldn't picture what part you were talking about.
Can you post a picture? Bob |
#4 |
Would the "angled floor panel" you speak of be what we call the "toe board" or "foot board"? That is, the sloping part of the floor between the horizontal floor and the firewall?
Yesterday is History. Tomorrow is a mystery. Enjoy Today. |
#5 |
he is talking the front trunk floor pan, that goes up at an angle and connects to the rear of the seat riser. on them two rivets I ground them out and cheated by using some of the head light rivets that are bolts and nuts. it is pretty tough to get to them with out taking things apart.
#6 |
Thread Tools | |
Display Modes | |
