Old 09-13-2020, 12:26 PM   #22
jrvariel48
jrvariel48's Avatar
Default Re: Crank pulley bolt...Lost again!!
Originally Posted by Ronnieroadster View Post
Joe in the past when I have experienced the exact same issue as yours even with the blower belt helping the dampening. The problem was due to a balance issue which turned out to be the flywheel area. Even red locktite would not help. I would suggest try green locktite its a lot stronger than red if the bolt still comes loose after going to green then checking the bolt regularly to be sure its tight would at least keep the bolt in place and not on the road someplace.
Ronnieroadster
Great advice as usual Ron, thank you
jrvariel48 is offline   Reply With Quote
