07-25-2014, 10:35 AM | #1 |
Brake adjustment of 31 Coupe with 39 Ford hydraulic brakes?
Where can I find out how to adjust the brakes on my Model A equipped with 39 Ford hydraulic brakes. My brake pedal has way too much free travel now that the brake linings have broken in from a couple thousand miles of driving. Do I have to remove the tires and wheels? Or is there a way to make wear adjustments on the backside of the brake backing plates?
John the Model A Rookie from North Carolina |
07-25-2014, 11:03 AM | #2 | |
Re: Brake adjustment of 31 Coupe with 39 Ford hydraulic brakes?
There should be a hex bolt coming through the backing plate. You pull down with a wrench until you feel a slight drag. There is a adjuster on the front and back of the backing plate. |
07-25-2014, 11:08 AM | #3 | |
Charlie Stephens |
07-25-2014, 11:56 AM | #4 |
I have them on my 29, and found the page suggested by Charlie very useful.
This may also help http://www.jalopyjournal.com/forum/t...your-a.124112/ http://www.lainefamily.com/ModelAFil...akeUpgrade.htm Generally the H.A.M.B. has more of this type of stuff than the Barn
Kevin Flood West Berkshire UK Member MAFCGB, VHRA, SAH, Brooklands Trust Sporadic progress on My 1929 Sport Coupe can be found here along with my blog http://automotiveamerican.com/ |
07-25-2014, 12:01 PM | #5 |
Back side of backing plates goodluck Also check free play at master cylinder
07-25-2014, 12:18 PM | #6 |
07-25-2014, 02:05 PM | #7 |
Nice to see all this info in one place. Hope I can find it again now.
