02-14-2014, 12:24 PM | #1 |
Ignition Options
I'm looking at upgrading the ignition system on my car.
Here are the options I'm looking at, what are your thoughts, experiences, opinions, prejudices? 1. Leave it alone!! I currently have a stock distributor and coil with "modern points" and a Snyders "B" distributor cam. I know, I know, the points set up was free and it works. 2. Petronix 6v coil #40011 and a Bill Stipe distributor Cam. Keep the manual advance 3. Convert a stock distributer to an FS set up. Still manual advance 4. Buy a "B" distributor and perform one of the above options to it. 5. Bubba's ignition Mallory. I like the looks, I like points and it advances itself. 6. Buy and rebuild a vintage dual point Mallory 7. A modern Mallory Single points with a red cap 8. FS distributor. The benefits of electronic ignition and centrifugal advance in one package. I plan to add a high compression head also at some point if that affects your opinion. Thanks in advance
Blackwall Panthers Nor Cal chapter Last edited by Tiny; 02-14-2014 at 12:38 PM. |
02-14-2014, 12:45 PM | #2 |
Re: Ignition Options
I'd go with #2 (just 'cause that's what I did). I have the NuRex cintrifugal advance, but haven't put it in yet. My friend down the street has this same set-up with the NuRex unit in his 29 Tudor and loves it.
02-14-2014, 01:52 PM | #3 |
There are several other options you didn't mention. Was that because of cost?
RotoFaze. Jacobs. MSD. Accel. |
02-14-2014, 01:58 PM | #4 |
I have both FS ignitions. I had to have the Zipper modified to a lower advance, and it works well. I also have the manual advance and it also works well. I always carry a spare distributer incase the module goes bad. (it hasn't in 4 years) You must be sure to hit the starter as soon as you turn on the key so you don't burn out the module. So far this has not been a problem. I would not have any other.
02-14-2014, 02:33 PM | #5 | |
Also looks is a factor. That's why the FS unit and the modern Mallory are at the bottom of the list
Blackwall Panthers Nor Cal chapter |
02-14-2014, 02:34 PM | #6 |
I've been into British cars for a while and have had excellent luck installing the MSD (CD) kit. It saves the points...they never burn out. It has incresed the driveability and accelleration in the 4 cars I have installed it on. Wouldn't his work on a Model A? You's probably want to hide or disguise the bright red module.
RobertB Santa Teresa, NM |
02-14-2014, 02:37 PM | #7 |
This is what scares me about electronic ingition
Blackwall Panthers Nor Cal chapter Last edited by Tiny; 02-14-2014 at 02:45 PM. |
02-14-2014, 02:53 PM | #8 |
What do you define as upgrade?
Do you want a car that runs 65 MPH, gets in the low 20's for MPG and is dependable for the next 4 or 5 decades with minimal maintenance? That is what my brothers car has for a history. Stock head, used B cam, used points, burnout proof condenser, and a wire stolen from a dist on an engine out behind a garage (he was a 15 year old with no morals!). Other then the burn out proof condenser it is untouched from the day he rebuilt it. Going to electronic stuff may make you immune from loose parts in the distributor giving you uneven dwell but it opens you up to voltage sensitivities. In other words, the electronic system will fix a worn distributor system or poor parts. The downsides.. A marginal battery means a tow home. Poor connections are going to be a problem. Paying attention to details and keeping original is your most reliable and robust system. Going too high in compression you will need to push the ignition system harder and electronics help. As far as better pep and power. Never experienced a switch to eletronics so I do not know. I do know my brother has had people complain he runs to fast and I had the same problem when driving my crappy looking 30 fordor. Keep in mind the people complaining were driving in cars newer then 1950. Most of you guys baby your A's too much and think you need modern to move along. Rebuild em right back to factory and thrash the heck out of them for the next 50 years. Remember the pedal on the right makes them go, do not be afraid to press it! Run em hard and put em away wet. They love that kind of abuse. |
02-14-2014, 03:01 PM | #9 |
On any of those names, your search engine will turn up their websites.
02-14-2014, 03:05 PM | #10 |
Kevin your funny!!!!!!!!
Not very helpful but funny
02-14-2014, 06:12 PM | #11 |
Restore it to original.
02-14-2014, 06:16 PM | #12 |
That's where I'm currently at. I forgot to mention that I did restore the one currently living in my car, but its a Model A it must be fiddled with and upgraded! Right?
02-14-2014, 10:20 PM | #13 |
Well, no, it really does not have to fiddled with and upgraded, but lots of folks like to fiddle with it and upgrade it anyway, but that's a personal problem, not a mechanical problem. The stock ignition is adequate for what it does and will work fine with an HC head too, although you will learn to use the advance lever better. The HC head is less forgiving, but the stock ignition can handle it. I actually got to like using and learning the manual advance at different settings with an HC head. (Different story if you want to go for high performance stuff with cams, carbs, porting, etc. See Jim Brierely's book if you are going that route.)
FWIW, when I started fiddling and upgrading, and started down the performance road, I put in the electronic and auto advance FS ignition and it works fine. And I get to keep fiddling with and upgrading the advance curve. Sort of like using the advance lever, but more complicated to do and get right. |
02-14-2014, 11:23 PM | #14 |
I am not looking for a top speed per se. What I am looking more is a little more umph. Ultimately I'd like too not totally dread hills. I wish I could build an all out banger motor but right now I would just a bit more seat of the pants feel. I think I'm leaning mostly at a B distributor, hot coil and Bill Stipe distributor cam with the extra dwell built in. I'm not unhappy with the stock setup I have. I rebuilt it myself and it performs well. I just what more. I can't help but think a rework of the ignition will be a good place to start.
Blackwall Panthers Nor Cal chapter Last edited by Tiny; 02-15-2014 at 01:59 AM. |
02-15-2014, 12:23 AM | #15 | |
Unless you're looking to cross that magic 1 horsepower per cubic inch threshold or exceed 5000 rpm or trying to run an engine with a damp & wet ignition, some of the over-the-top systems mentioned achieve little more than bragging rights. |
02-15-2014, 12:43 AM | #16 |
Well said Mike and Kevin!
Larry S. |
02-15-2014, 01:18 AM | #17 |
02-15-2014, 01:48 AM | #18 |
I agree with Mike and would install the Snyder's high compression head. Best bang for the buck.
02-15-2014, 08:50 AM | #19 |
Thank you Mike X2.
The one thing that always makes me wonder in circumstances like this is; ...is the original system truly under-performing? New correctly gapped spark plugs will tell a lot after a 5-mile drive. Rebuilding the distributor may not do a thing if the coil is weak or the polarity reversed. The same might be said if the timing is off, and/or if the carburetor is not performing correctly. If the camshaft is worn under specs, then naturally the entire engine will be down on power and again, switching to an aftermarket distributor will not do anything except make your wallet thinner IMHO. |
02-15-2014, 09:13 AM | #20 |
Going through the mountains of PA in my brothers 31 coupe we were passing modern cars on the uphill side.
That was a stock engine with a used B cam. I was very serious with my comments earlier. A worn out A a was thrashed daily by kids into the 60's. A properly rebuilt A can take quite a bit hard driving and live a very long life. They were not designed to be babied. A thrown together out of balanced engine will never have the power that it should have. |
