Old 04-16-2013, 12:10 PM   #1
farmputzer
Default Enamel paint when it is cool out?
What happens if you paint the frame with enamel paint when it is only 40-45 degrees out?
farmputzer is offline   Reply With Quote
Old 04-16-2013, 01:03 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Enamel paint when it is cool out?
Nothing as long as it is catalyzed and allowed to slowly cure. Forcing the paint to cure too quickly generally creates a brittle paint.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-16-2013, 01:45 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Chuck painted Minerva's fenders, splash panels, etc, with synthetic enamel & some kind of hardner. After sitting in the sun for only 2 days, he was able to cut & polish them, amazing & beautiful job. He also cut & polished the body that had black lacquer from '96. God! the car looked like a total quality repaint!! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-16-2013, 01:51 PM   #4
Mitch//pa
now i am mixed up who is vermin and who is minerva. are they 2 separate cars?
parker is asking
Old 04-16-2013, 04:17 PM   #5
flatford39
Your probably OK with enamel if you have the right amount of hardener in it. Just let it dry and gas out naturally. I would give it a couple of weeks before cutting and buffing.
I prefer painting in a controlled environment due to humidity and seldom lay color down when it is that cold. Paints expensive...I suspect you know that.
flatford39 is offline   Reply With Quote
Old 04-16-2013, 06:19 PM   #6
BILL WILLIAMSON
parker is asking
Howdy, Parker! Buster T. here, you think you mixed up? Ol' Bill still orders parts for Minerva, the Fast Black Early'30 Std. Coupe he sold 'cause he was broke, instead of gettin' parts for Vermin, the Black & Blue, (Sounds like the bruise on Bill's arm) Early '29 Coupe. (Not a "special" just a plain old coupe, but Ol' Bill likes him!) Bill's O.K, though, he named him Vermin just for me 'cause I'm a "BORN" rodent killer, Jack's Ratter kills SNAKES too, I ain't got me one yet, Bill teases me with his yeller rubber snake, I ACT scared! His rubber hen is ridiculous---What's a Dog to do?? Hey, Parker, have a GRRRGRRRGRRREAT DAY Fluster T. (Both his cars have been MAFCA's "Cars of The Day" some time ago, WHOOPIE!)
Old 04-16-2013, 06:56 PM   #7
Logan
Logan's Avatar
Check with the paint rep that sold you the paint. Probably best if you can find a heated garage to spray in. A lot of paints stop curring bellow 65 degrees. I wouldn't paint in 45 degrees, because your metal will be cold and could cause more problems than it's worth by rushing the process. We're only a few weeks away from summer time.
Cowtown A's
Logan is offline   Reply With Quote
Old 04-16-2013, 11:18 PM   #8
28ACoupe
28ACoupe's Avatar
I have shot acrylic enamel at 0F before. I don't recommend it but you can get away with it if you are patient and know what you are doing with the paint.
1928 Model A Business Coupe
Rebuild picture gallery here
The light at the end of the tunnel has been turned off due to budget cuts.
28ACoupe is offline   Reply With Quote
Old 04-16-2013, 11:20 PM   #9
Dick Webber
Paint people always told me that catalyzed paints won't cure properly below 60-65 degrees.
Dick Webber is offline   Reply With Quote
Old 04-17-2013, 12:12 AM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
That's what I was told and I would never shoot paint under 65*. That really limits the days in Minnesota if you don't have a heated garage.
Old 04-17-2013, 07:40 PM   #11
Tinbasher
Tinbasher's Avatar
55 Deg.s is about as low as you would like to go. Below that it will take a long time between coats for the paint to flash off. It can be done but it's a toss of the dice.
I remember painting in 32 deg.s and it took hours for the paint to flash and boy did it run!!
The joy's of youth!!
The Old Tinbasher
Tinbasher is offline   Reply With Quote
