Old 07-25-2014, 10:35 AM   #1
joltesvig
joltesvig's Avatar
Default Brake adjustment of 31 Coupe with 39 Ford hydraulic brakes?
Where can I find out how to adjust the brakes on my Model A equipped with 39 Ford hydraulic brakes. My brake pedal has way too much free travel now that the brake linings have broken in from a couple thousand miles of driving. Do I have to remove the tires and wheels? Or is there a way to make wear adjustments on the backside of the brake backing plates?
John the Model A Rookie from North Carolina
joltesvig is offline   Reply With Quote
Old 07-25-2014, 11:03 AM   #2
George Miller
George Miller's Avatar
Default Re: Brake adjustment of 31 Coupe with 39 Ford hydraulic brakes?
There should be a hex bolt coming through the backing plate. You pull down with a wrench until you feel a slight drag. There is a adjuster on the front and back of the backing plate.
George Miller is offline   Reply With Quote
Old 07-25-2014, 11:08 AM   #3
Charlie Stephens
And the long answer is here: http://www.btc-bci.com/~billben/brakeadj.html Note that the illustration is an x-ray and you are looking at the back of the backing plate, you do not need to remove the wheels and tires to adjust the brakes.
Charlie Stephens
Old 07-25-2014, 11:56 AM   #4
Charlville
Charlville's Avatar
I have them on my 29, and found the page suggested by Charlie very useful.
This may also help
http://www.jalopyjournal.com/forum/t...your-a.124112/
http://www.lainefamily.com/ModelAFil...akeUpgrade.htm
Generally the H.A.M.B. has more of this type of stuff than the Barn
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 07-25-2014, 12:01 PM   #5
billwill
Back side of backing plates goodluck Also check free play at master cylinder
billwill is offline   Reply With Quote
Old 07-25-2014, 12:18 PM   #6
bill44
bill44's Avatar
Les Andrew's green book covers hydraulic brakes.
bill44 is offline   Reply With Quote
Old 07-25-2014, 02:05 PM   #7
Rex_A_Lott
Nice to see all this info in one place. Hope I can find it again now.
Rex_A_Lott is offline   Reply With Quote
