12-28-2021, 06:34 PM | #1 |
C4 Transmission Vent
There are two types of vents, tube and jiggle pin. Is one better than the other? The jiggle pin on the top of the tail shaft is a cleaner look. Although I have a later transmission, it has the vent tube. I would prefer to replace the tube with a jiggle pin.
12-28-2021, 06:52 PM | #2 |
Re: C4 Transmission Vent
Looking at my transmission, again, I see that the tube is attached to the top of the main case. Nevertheless, I'm thinking the tube can be removed, and a jiggle pin can take its place. The vent hole might have to be drilled and tapped for the jiggle pin, but the transmission has been removed and will soon be rebuilt, during which the jiggle vent can be installed.
12-29-2021, 05:56 PM | #3 |
Wrong, again. The vent tube is in the tail shaft, but very close to where the tail shaft attaches to the main case. Poor lighting and old eyes don't help.
12-29-2021, 08:24 PM | #4 |
- https://www.raceabilene.com/kelly/hotrod/trans.html
- https://www.fordmuscleforums.com/thr...rsion2.416584/ - https://www.motortrend.com/how-to/md...ansmission-c4/ Last edited by KULTULZ; 12-29-2021 at 08:48 PM. |
01-04-2022, 10:51 AM | #5 |
They likely changed it due to the possibility of crud getting into the tube. Here in south Texas we have the mud dauber type wasps and they like to make nests inside tubes like those early C4s had. |
