09-04-2021, 11:49 PM | #21 |
Re: What Y-Block camshafts work well with automatic transmissions?
Who manufactures a billet flat-tappet cam for anything other than diesels?
09-05-2021, 02:30 AM | #22 |
This may be a better option,a lot of guys on the H.A.M.B. use them for vintage engine camshafts instead of buying a "Cam in a box" camshaft if you give them the exact specs of your engine and it's intended use they can grind you a custom grind to fit your exact needs. https://deltacam.com/ They also can apply a hardening to better withstand today's engine oils.
09-05-2021, 10:39 AM | #23 |
oregoncamshaft.com also good. They can regrind your cam or provide new.They know Fords. Tim McMaster (y-blockguy) uses them. They also resurface y-block lifters.
09-05-2021, 03:35 PM | #24 |
If you decide to go with a steel billet, have Jones Cams do it.
[email protected] Mike Jones designs and grinds cams for many of the top teams in just about any type of racing there is. He can do a steel billet, furnish the special lifters required and furnish the special distributor drive gear required. All at a reasonable price. Tell him I sent you and he might only raise the price 10%....LOL |
09-05-2021, 03:35 PM | #25 |
09-05-2021, 04:50 PM | #26 |
09-05-2021, 04:55 PM | #27 |
I had them at one time. He should still have that stuff.
