Old 09-28-2013, 02:05 PM   #1
jkcrosson
jkcrosson's Avatar
Default Faulty Brake light switch
Yesterday, I go to crank the A. After 6-7 turns, it has not fired yet. I check and I have a blown fuse. I replace the fuse and immediately, it burns out again. Today, I isolate the problem down to the brake light switch. I suspect that I put a reproduction switch on the car in the 90s but could not swear to that. Is my only option for eliminating brake light switch woes to replace with an original. I have read that A&L has a good 30-31 but not the one that mounts on the side of the transmission. What are my options?
Jamie Crosson
1929 Tudor
Looking for an Original 888 Key
jkcrosson is offline   Reply With Quote
Old 09-28-2013, 03:06 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Faulty Brake light switch
Try doing a search, I believe Tom Endy did a thread on how to ck, disassemble, adj, and lube=as good as new.
Paul in CT
Old 09-28-2013, 05:26 PM   #3
KMeredith87
KMeredith87's Avatar
I just had a similar problem and replaced it with another repro...complete junk! After some research through the old post I found A&L parts who kakes an exact reproduction of the original a little pricey, $40, but completely worth it as it took no adjusting or extra work to eliminate my
KMeredith87 is offline   Reply With Quote
Old 09-28-2013, 06:07 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
The tranny mounted switch is easy to fix. See my pictures in reply #4
http://www.fordbarn.com/forum/showth...itch+wesenberg
Old 09-28-2013, 06:49 PM   #5
jkcrosson
jkcrosson's Avatar
Thanks Guys. I'll pull it apart the first of the week.
Jamie Crosson
1929 Tudor
Old 09-28-2013, 06:56 PM   #6
Tom Wesenberg
You might need to heat the tabs red hot so they don't break. I've done a couple switches without heat, but you can tell they will never take another bending. I also have a cover or two that will need a few tabs welded back on.
Old 11-25-2013, 02:47 PM   #7
Stew
Stew's Avatar
I was having a problem with my 31 pickup brake light switch. I took the advice from one of the posts with a slight twist. Mine is the cross member type switch. I threaded the shaft of the switch with a 10-24 thread then I put a lock nut with a nylon insert flush with the end of the shaft. Then I slightly enlarged the hole in the cross member where the shaft goes through to ensure good clearance. The nut gives a much bigger mating surface for the plunger.
Problem solved
Stew is offline   Reply With Quote
