Old 06-24-2021, 03:47 PM   #1
Tom's36coupe
Tom's36coupe's Avatar
Default Best way to Detail running board covers
Have cleaned my new running board covers but have a few gray areas and would like them to be more uniform, black . Was not wanting to put Armor All or something like that as its oily and would attract dirt. What is best to use for show appearance . Thanks
Tom's36coupe is offline   Reply With Quote
Old 06-24-2021, 04:09 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: Best way to Detail running board covers
I have used Kiwi shoe polish for 48 years on my original rubber running board rubber. Put it on heavy let it dry them buff off with an old towel. I love it. Non greasy
Old 06-24-2021, 04:23 PM   #3
Will D
Will D's Avatar
"Protectant 303" I use on all things rubber. Running boards, wipers, window seals....works great.
The shoe polish may work best to get rid of your Grey areas tho.
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 06-24-2021, 04:26 PM   #4
Kube
Kube's Avatar
Spot on!
I still have a couple cans of the "old" Turtle Wax for vinyl tops. Nothing more than shoe polish with a giant dauber. Works great.
Old 06-24-2021, 05:23 PM   #5
Digger
Digger's Avatar
Mask them off good, spray them with SEM Landau Black, nothing better….
Digger is offline   Reply With Quote
Old 06-24-2021, 05:47 PM   #6
cmbrucew
cmbrucew's Avatar
DOT #3 brake fluid.
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 06-24-2021, 06:36 PM   #7
TJ
TJ's Avatar
I use Meguiar's Natural Shine. I spray it on a towel and rub it on. Gives a nice natural look. Not greasy like Amorall which I quit using years a go. Nasty stuff that attracts dirt.
Old 06-24-2021, 07:19 PM   #8
37 Coupe
37 Coupe's Avatar
I use a product called Back to Black.I think it is the Mothers polish line of products.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 06-24-2021, 08:25 PM   #9
Pat's Ride
Pat's Ride's Avatar
A few good ideas, I'm going follow along as I need to freshen mine up.
Pat's Ride is offline   Reply With Quote
Old 06-24-2021, 10:10 PM   #10
fordor41
fordor41's Avatar
Ditto on black shoe polish
fordor41 is offline   Reply With Quote
Old 06-25-2021, 08:18 AM   #11
DavidG
DavidG's Avatar
Since they are new, Meguiar's "Final Inspection" spray should remove the mold release remnants which is what is causing the lack of color uniformity.
Old 06-25-2021, 09:00 AM   #12
KiWinUS
KiWinUS's Avatar
If you watched “”The World’s Fastest Indian “. You would know a second advantage to Kiwi shoe polish. The stuff in the flat can.
Old 06-25-2021, 11:04 AM   #13
Tom's36coupe
Sounds interesting, thanks to all!
Old 06-25-2021, 12:59 PM   #14
DavidG
DavidG's Avatar
Why would anyone want to put shoe or any other kind of polish on top of residual mold release chemicals? These are new covers; they're like new tires, they come with residual mold release gunk on them. The first step is to clean off that stuff and then see if the color disparity still exists.
Old 06-25-2021, 02:23 PM   #15
hotrodart
hotrodart's Avatar
I use Simple Green on mine to get them clean. Great results.
hotrodart is offline   Reply With Quote
Old 06-25-2021, 11:47 PM   #16
Newc
Newc's Avatar
natural rubber is white.. Over the yrs I have heard of some gray showing up, and even a batch of new boards had some gray show up, a few yrs back. Newc
Old 06-26-2021, 12:54 PM   #17
woodiewagon46
I also use the 303 Protectant. I spray it on the running board and work it in with a 1" chip brush and wipe it down with a clean cloth.
woodiewagon46 is offline   Reply With Quote
