08-05-2022, 05:21 PM | #1 |
Turn signal using existing tail lights
I don’t seem to hook up rear brake and tail ligwith signal.
Jimmy Palmer |
08-05-2022, 07:13 PM | #2 |
Re: Turn signal using existing tail lights
Signal-stat 900. It comes with instructions.
08-06-2022, 01:35 PM | #3 |
JD, The brake light signal goes through the turn indicator switch. The wire from the brake light switch will have to be run to the indicator switch. Consult the instructions that came with the turn indicator kit or find the instructions online.
08-07-2022, 03:38 PM | #4 |
Ok so the original wiring to the brake and run light you leave out at rear and run through the turn signal. You don’t run extra wire back to the rear brake light’s
Jimmy Palmer |
08-07-2022, 03:48 PM | #5 |
[QUOTE=jdpalmer;2155196]Ok so the original wiring to the brake and run light you leave out at rear and run through the turn signal. You don’t run extra wire back to the rear brake light’s for signals?
Jimmy Palmer |
08-07-2022, 04:01 PM | #6 |
You can use the green wire going to the brake lights, for one side and add an additional wire for the other side brake light. |
08-07-2022, 08:01 PM | #7 |
Herb has the right idea. The two brake lights become combination signal and brake lights and are run to the indicator switch. The brake light switch is then run to the indicator switch. The running lights still are run as original. Look at the wiring diagram that came with the kit or look up the wiring diagram online.
If everything is wired correctly both brake lights will come on when you press on the brake and one will blink if the brake and indicator switch are both on. If only the indicator switch is on then one brake light will blink and the opposite one will be off.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 08-08-2022 at 05:05 AM. |
08-08-2022, 10:33 AM | #8 |
You need a 7-wire directional switch and a set of instructions, unless the wires are labeled.
08-08-2022, 11:24 AM | #9 |
One can only offer just so much help.
Once again, get a good turn switch such as a Signal-Stat 900 and follow the directions. It kinda sounds as if he is trying to do this with a toggle switch. A wiring diagram is still needed. |
08-08-2022, 05:29 PM | #10 |
If a double filament bulb and double contact base can be fitted to the lower running lights, they could be used as turn signals ,wire the higher candle power bulb to turn signal each side will have a separate wire for left and right. The running lights will have one wire connecting them to light switch.
08-08-2022, 07:59 PM | #11 |
Hmm… Maybe this will help?
http://forum.aths.org/Attachment11161.aspx Sent from my iPhone using Tapatalk |
08-08-2022, 08:26 PM | #12 |
I reckon I forgot in the beginning that they were wired up and worked. I run a separate wire to each brake light for the signal from the indicator. The run was left as it was and so was the brake green wire. My problem now sometimes both blink and sometimes the right run light blinks . I though bad ground as I had crazy thing with a trailer light and it was a bad ground so I temporarily run ground fro taillight bucket to frame. This worked a few times then went crazy again.
Jimmy Palmer |
