08-07-2022, 10:52 AM | #21 |
Re: Battery Charger
Battery Hydrometer or Battery Specific Gravity Tester.
The Master Cylinder Enjoying life at the beach in SoCal... |
08-07-2022, 11:05 AM | #22 |
Re: Battery Charger
Why do you have to make everything political?
Ruth "Sometimes you really DO need to read the whole thread" |
08-07-2022, 11:49 AM | #23 |
Re: Battery Charger
I was just about to say EXACTLY what katy has said especially if they are GLASS which can turn.
I don't care if the "A" Starts BUT sure WANT IT TO STOP! |
08-07-2022, 12:01 PM | #24 |
Re: Battery Charger
Many a lazy electrician has been fooled by testing fuses in the holders! remove the fuse a test. Cartridge fuses are the worst, pull the fuses and check for continuity !
08-08-2022, 04:48 PM | #25 |
Re: Battery Charger
I just reread the charger instructions and discovered I made a dumb mistake. They say to attach the cable to the battery and then plug in the charger. I did the opposite. Re-read the directions and did it right. They battery charges fine now. But, I discovered a new potential issue. My car has an alternator. I have a feeling that may be another problem. I'm thinking about swapping it out for a generator. As far as I know, all Model A's were originally built with a generator. But, I know people do the opposite and install an alternator. So, which works best?
08-20-2022, 07:46 PM | #26 |
Re: Battery Charger
