06-15-2022, 05:37 AM | #1 |
Death Wobble
Good morning all! So I took my ‘30 Tudor for a slow ride around the block few times since I bought it. Last ride I was close to home driving down hill and here she goes…Death wobble! I jacked up the front end the king pins seem nice and tight as well as the other front end components. Steering is nice and responsive not much play but I did find the front wheel bearings are worn and one of the race was completely loose. The tires are horrible hence the short trip to test a few things. Can the wheel bearing’s and race cause the wobble or should I dig deeper in the front end?
06-15-2022, 05:40 AM | #2 |
Re: Death Wobble
Anything that is loose or not adjusted correctly can cause it. That is, anything from the steering box all the way thru to the wheel bearings and anything in between.
06-15-2022, 07:01 AM | #3 |
Re: Death Wobble
Check the toe in first. It is a primary source of wobble, and it is not difficult to do.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" |
06-15-2022, 07:21 AM | #4 |
Re: Death Wobble
Fix the bearings and tires. Then go for another drive. Anything that is loose in your front end will contribute to a car shimming.
Enjoy. |
06-15-2022, 07:59 AM | #5 |
Re: Death Wobble
Look for loose hub races as well within the hub. Remove the front hub from the spindle and see if the outer race turns at all with your fingers . If it does the hub is enlarged and you will need a new one.
Lots of things to check but it is important to ensure that all components are tight and up to standards. Here’s a quick list . 1. Spring not sagged , has gap between axle and bottom of spring 2. Steering at center check to see if there is more than and inch play at wheel. Is pitman arm tight , if steering arm plugs are screwed in pst outer edge there is probably worn components, steering balls and internal cap and springs on the tied rod and drag link 3. Steering box itself , adjustment and/or worn 4. Make sure it has original style steel radius cap assembly, not rubber ball 5. Spring clamp bolts tight!! 6. Front brake issues ? 7. Check toe in after verifying all above and correcting Set to in to 1/16 . Top issues above that cause issues. Once resolved will be a different car. Larry Shepard Last edited by larrys40; 06-15-2022 at 09:57 AM. |
06-15-2022, 08:43 AM | #6 | |
Re: Death Wobble
I second this! I bought the tool and got it aligned. It fixed it.....but for some reason it came back. Not as bad, but it did. Maybe I didn't tighten something back up? |
06-15-2022, 08:54 AM | #7 |
Re: Death Wobble
06-15-2022, 09:49 AM | #8 |
Re: Death Wobble
When the king pins and the spring bolt bushings seem tight, go to your steering balls. They're supposed to be 1.000" all around. Some are so flattened out it's hard to believe that they were ever balls. Chasing down "Death wobble" can be a frustrating experience!
Terry |
06-15-2022, 10:35 AM | #9 | |
Re: Death Wobble
06-15-2022, 10:47 AM | #10 |
Re: Death Wobble
Yep, once the front end is nice and tight, set the toe-in to 1/32-1/16".
If a bearing fits loose in hub or over spindle, 2 small prick punches in line and spaced at 90* from each row [ 8 total] will tighten and center them. Thats an old Ford trick that I didn't agree with until the factory rep convinced me to do it. I was just a kid at the time and that trick worked. Many many new Fords came thru with that issue. Did it a number of times after that. |
06-15-2022, 10:50 AM | #11 |
Re: Death Wobble
I've found the drag link and tie rod ends to be the most troublesome. Everything must be tight!
06-15-2022, 12:30 PM | #12 | |
Re: Death Wobble
Terry |
06-15-2022, 02:05 PM | #13 |
Re: Death Wobble
Awesome thanks everyone I’ll get at it!
06-15-2022, 02:09 PM | #14 | |
Re: Death Wobble
Yep ! Did it to a c150 a couple decades ago. Some folks were complaining about the shimmy, just told them to keep the weight off the nose. "Never had a bad landing from it" Good. Keep the weight on the mains. There are other times when it comes in handy. Some folks like to argue that its not a quality fix. I thought the same until our Ford rep convinced me otherwise. |
06-15-2022, 02:22 PM | #15 |
Re: Death Wobble
There was a guy on the forum a while back with the same problem. It turned out to be a bad ball/fitting at the end of the radius arms, where it mounts to the bottom of the bell housing.
06-15-2022, 02:36 PM | #16 |
Re: Death Wobble
Don't forget to oil the spring and grease the shackles.
06-15-2022, 04:53 PM | #17 | |
Re: Death Wobble
Guys, there is a section regarding the front end geometry of an early auto, (Model A) in the Dyke's Encyclopedia of Automobiles and Gasoline Engines. My version is the 1948 release of this book. It explains front end wobble far better than I can type in. In fact, a copy of this book will open a whole new world of understanding to even the most experienced mechanics on a number of topics. So much to learn...I need at least 5 more lifetimes...
06-15-2022, 04:57 PM | #18 |
Re: Death Wobble
Yep, tires soon. Also found shock arms were loose and theiry setting was incorrect for the temperatures. (Bratton's sealed repro shocks) Tires are old, but no signs of failure, probably stiff as heck and out of balance. Out of balance can cause wobble due to front end geometry (inclination) as I recall. Our coupe does not have the death wobble, but does have wheel bounce and a slight wobble between 40-45mph. Above 45 it actually smooths out.
The car's tire and wheels are less than 1/8th inch when tested with a stationary pointer front to rear and 90 degrees, side to side. I put 5 oz of antifreeze in the tubes, but it has had little effect. As I said, tires and tubes soon.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" Last edited by Rob Doe; 06-15-2022 at 05:03 PM. |
06-15-2022, 05:39 PM | #19 | |
Re: Death Wobble
Good one Neil. I still need to drop the ball down and measure it.
06-16-2022, 10:05 AM | #20 |
Re: Death Wobble
What's the anti-freeze supposed to do?
