10-28-2021, 02:30 PM | #1 |
Accelerator Help needed 1945 Ford 1/2 Ton Pickup
Hi all,
I'm trying to hook up my Accelerator Linkage to the firewall, however it's not making sense to me. I've got the spring on. Where the spring goes on the bell looking spacer. Does this connect to the firewall? (It looks as though it is to make space between to connecting rod and the firewall) but, bolt is not long enough to go through the firewall. Any help is much appreciated. 1 linkage.jpg 2 Linkage.jpg
Thanks, Will “1Tim 3:16 And without controversy great is the mystery of godliness: God was manifest in the flesh, justified in the Spirit, seen of angels, preached unto the Gentiles, believed on in the world, received up into glory.” |
10-28-2021, 03:01 PM | #2 |
Re: Accelerator Help needed 1945 Ford 1/2 Ton Pickup
Not sure about the 1945 but on my 1948 F2 the bell shaped part goes inside
the cab and helps hold the firewall insulation. |
10-28-2021, 03:32 PM | #3 |
Thank you,
I'll see if that works.
10-28-2021, 10:41 PM | #4 |
The "bell shaped" part is really a spacer for the firewall cover. The "top" of the bell is inserted into the hole in the firewall cover so it bottoms out against the firewall to where the "top" of the bell is flush up against the metal firewall. Thus, only a very short bolt is required to go through the equivalent of two pieces of sheet metal.
10-28-2021, 11:14 PM | #5 | |
Thanks
10-29-2021, 12:39 AM | #6 |
It’s great we’ve all got a group like this to bounce questions off of ….!!!
Whether you think that you can,or that you can't,you are usually right....H.Ford |
Thread Tools | |
Display Modes | |
