09-28-2012, 01:47 PM | #1 |
Tachometer
People can you tell me where to attach the signal wire from a tachometer on a my A. I attached it to the point side of the coil and I think I just recked my second tach
thanks dusty |
09-28-2012, 02:46 PM | #2 |
Re: Tachometer
Are you setup positive or negative ground?
Which coil post did you connect to?
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
09-28-2012, 02:54 PM | #3 |
Re: Tachometer
On most electronic tachs you have to set it for 4-cylinder as well, Usually a jumper or switch to set for 4, 6 or 8 cyl.
My set up is 12v neg ground, and I have the signal wire on the output side (RH) of the coil. |
09-28-2012, 03:20 PM | #4 |
Re: Tachometer
09-28-2012, 03:23 PM | #5 | |
Re: Tachometer
I set the tach to 4 cyclinder and attached it to the coil side that feeds the distrubuter. This would be the left hand side while sitting in the car. thanks dusty |
09-28-2012, 05:20 PM | #6 |
Re: Tachometer
09-28-2012, 05:40 PM | #7 |
Re: Tachometer
Forget "right or left" side of coil. These wires can be hooked up on either side of the coil, and the coil can go in either way (with (+) post on left or right).
Connecting to the side that connects to the points is correct. The coil should have a little (-) sign next to that post, because your car is negative ground (if it's wired correctly). That's all that matters. I don't know why it is frying your tachs. Do you have electronic ignition? Are you using a 12 volt coil? (internal ballast) or an external ballast?
09-28-2012, 07:44 PM | #8 | |
Re: Tachometer
thanks dusty |
09-28-2012, 09:28 PM | #9 |
Re: Tachometer
No, a resistor is good to have (if it's in the right place). This may be one of those cases where you really need to take some voltage readings at various spots to understand what is going on.
You do not normally want the tach hooked up to the side of the coil that has the ballast resistor feeding into it. (That's assuming your car is wired properly.) That should be the power feed to the coil (to the (+) post on a negative ground car). And then the points connect to the (-) terminal of the coil to make and break the ground connection. Is your key switch connected to the power feed side of the coil or to the wire that runs from the coil to the points?
09-28-2012, 10:48 PM | #10 |
Re: Tachometer
Where are you getting your power (12v+) for your tach?
IF - your car is wired stock, and you are trying to power your tach from the ignition switch, there's a good possibility that it will indeed fry anything you put on there. You need a clean power source. Initially, I just ran a wire from the fuse block on the starter, thru a toggle switch, then to the tach. That worked till I had the chance to re-wire things so that the ignition switch was switching clean power. |
09-28-2012, 11:55 PM | #11 |
Re: Tachometer
Not to be argumentative, but how are you sure you "fried" the tach? Maybe it was just hooked up wrong and did not work?
09-29-2012, 08:01 AM | #12 |
Re: Tachometer
The key switch is attached to the power side of the resistor, that is the only switch 12 volt power source I have, the tach also needs a constant 12 volt power source and I have many of those. The tach signal wire was hooked to the point side of the coil. Negative wire from tach was hooked to the body,I have a negative ground car.Yes the tach is fried because it would swing to full when first turned on and reset to zero and now it just sits at 1000 rpm on or off.
09-29-2012, 09:42 AM | #13 |
Re: Tachometer
I wish somebody made a six volt four cylinder tachometer that looked like the old Sun tachometers. I have a small tachometer that is six volts that I bought from Berts that works great but does not look period correct.
I have an old Stewart Warner mechanical drive tachometer but do not have a way to drive it off of the crank shaft. If somebody has a way to drive a mechanical tachometer on a Model "A" engine, I would be Interested in some information or pictures.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
09-29-2012, 10:26 AM | #14 | |
Re: Tachometer
http://www.stipemachine.com/index_files/page0017.htm |
09-29-2012, 10:54 AM | #15 | |
Re: Tachometer
I clicked on the link but I could not get an link on the site. Nothing was click-able. I wanted to see what it looked like. I went Google and found the site. Nothing was click able on the site. Looks like some good stuff but can not get a picture or information.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. Last edited by sturgis 39; 09-29-2012 at 11:48 AM. Reason: added google search paragraph |
09-29-2012, 09:43 PM | #16 |
Re: Tachometer
I smell a slight hijack
09-29-2012, 09:54 PM | #17 |
Re: Tachometer
curious : what kind of tach ?
V4f |
09-29-2012, 11:43 PM | #18 |
Re: Tachometer
10-01-2012, 12:50 AM | #19 |
Re: Tachometer
Glow Shift, it was the most reasonble tach I could find that would fit in the 2 1/16 inch opening of the gauge bracket. I did go to Auto Zone and bought a tach that I will mount on the steer wheel column and it works perfectly.
For what ever reason the Glow Shift gauge is not compatable. So the lesson is going cheap will always cost you more Someone suggested here that I fill the vacant hole in the dual mount bracket( I have a water temp gauge on the other side) with an hour meter and thought hey that's a good idea and I found a round one and it was cheap dusty |
10-01-2012, 05:07 AM | #20 |
Re: Tachometer
Are you using a pop out ignition or a simple on/off switch?
