08-09-2012, 12:44 PM | #21 |
Re: Play causing front end shake?
Has anyone ever installed a steering stabilizer shock on their Model A, and how did it work out? We saw a kit in either Brattons or Snyders catalog and were curious as to if anyone has used one of these.
08-09-2012, 01:51 PM | #22 |
I think it's just a "mask" to hide what's wrong. JMO
Paul in CT |
08-09-2012, 04:53 PM | #23 |
Do Not short-cut with a stabilizer. The kid and I just rebuilt the front end and the further we got into the job the more apparent it became that the car had in fact been a danger. A stabliizer would have masked problems and could have put others in danger. Many 80 year old parts were just plain worn out and others had been improperly installed or maintained. About the only thing that went back in untouched were the king pins and the tie rod itself but with new ends and guts.
It seemed like an impossible task at the beginning but lots of time with the catalogs and Les Andrews book allowed even a couple of rank amateurs (don't be fooled by the promotion from Junior Member to Member) to do credible job. The front end is now tight and I believe major safety issues have been addressed. I have to give credit to Steve at Bert's who would not sell me a stabilizer, instead telling me to find and fix the problems. Thanks Steve, it the best Model A advice I've had so far. |
08-11-2012, 10:32 PM | #24 |
Well, we are going to work on it tomorrow (Sunday) hopefully, so I hope to have some news to report.
1929 Model A Ford Coupe |
08-12-2012, 08:33 PM | #25 |
OK, so my father in law helped me go over everything. Only thing that seemed weird was the drag link to the pitman arm had play. Took that apart, seemed okay, put it back together. Tightened it and play was gone. The end was screwed in very tight and not flush with the drag link head, is that an issue? Drove the car tonight and the bad shake is still there. We are running out of ideas, everything else looks good. Thinking of getting the drag link rebuild. Maybe tdl can chime in with any info he thinks is pertinent.
08-12-2012, 09:02 PM | #26 |
Re: Play causing front end shake? *UPDATED*
Did you drop the radius rods and inspect it's parts? We had a mostly decomposed rubber ball which I replaced with radius cap washer. |
08-13-2012, 02:01 AM | #27 | |
08-13-2012, 09:08 AM | #28 | |
We did not drop the radius ball. Is that a tough task to do?
08-13-2012, 09:35 AM | #29 |
do you have shocks? if not, a weak front spring can allow the front end to pendulum side to side..
08-13-2012, 10:58 AM | #30 |
No I do not have shocks. I have them, but they are not installed.
08-13-2012, 12:10 PM | #31 |
with out shocks and with a weak front spring the front axle is free to swing on the shackles. I've not tried, but you may be able get the front end off the ground, supported by the frame and see if the axle will pendulum (driver side to passenger side and back)..may be the cause. Don't let it fall on you..
08-13-2012, 01:18 PM | #32 |
I'm going to redo the tie rod and the drag link with new ends and look at the radius ball and go from there like others have suggested. The thing we saw with the radius ball is to remove the castle nuts to get to it the bolt or stud was just spinning. What is that a sign of?
08-13-2012, 01:20 PM | #33 | |
08-13-2012, 01:21 PM | #34 | |
http://www.abarnyard.com/ |
08-13-2012, 01:29 PM | #35 |
So jack the whole car up and put it on stands then?
08-13-2012, 04:15 PM | #36 |
Actually that would be the same as rocking the car as is, on the driveway.
If the bolts spin while trying to remove the castle nuts, then the pockets for the bolt heads have worn down enough for the bolt heads to drop low enough to not catch the cross pin, which is to lock the bolts from turning. This is an easy fix by just making small diameter washers to fit under the bolt heads to act as spacers, which lift the bolts the correct amount to engage the cross pin. You'll have to lift up on the castle nuts while unscrewing the nuts. Hopefully by lifting up you can engage the cross pin. |
08-13-2012, 05:15 PM | #37 |
Is the cross pin still in there?
Fred Kroon 1929 Std Coupe 1929 Huckster |
08-13-2012, 07:09 PM | #38 |
Yes, the cross pin does appear to be there. How can we gain access to the bolt heads to install washers under the heads? I could not see any way to access the heads of the bolts, they appear to be located in the bell housing and I don't know how to get at them, short of pulling the engine. Is there some hidden access panel or secret way to get at the radius ball bolts?
08-14-2012, 12:11 AM | #39 |
I switched out my rubber cap with the correct kit about 20 years ago on my 29 Tudor and did the complete job by blocking the wishbone down a few inches and installing the bolts and felt through the hole in the bottom of the housing. It wasn't too bad a job. I made some thin small diameter washers to fit under the bolt heads to take care of the worn recess and used my fingers and some wire to fish them through the hole.
08-14-2012, 05:38 AM | #40 |
I agree that there is something loose that you're not catching yet.. Regarding the shocks, the lack of them shouldn't cause the shimmy,, but,, they will certainly affect the handling and ride.. You didn't say which shocks you had,, if they are good originals or those from Bill Stipe,, thats good.. If they are the new 'oil-less' ones[I won't mention the makers name],, they are useless..
