05-03-2012, 01:29 PM | #101 |
Re: 1930 Model AA Cant Get Her Over 25 MPH
No leaks detected at manifolds on wd40 trick. I think I have it kinda dialled in now, but hey its hard to tell how good its actually running when you have no stock model A driving experience to compare to.....
05-03-2012, 01:30 PM | #102 |
This is true and I have ordered some literature, but I'm waiting for it to arrive and I am not a patient person. LOL. Lot of great help here too, so, thanks guys....
05-03-2012, 01:47 PM | #103 | |
No Model A clubs around? Your profile does not say where you live. |
05-03-2012, 02:03 PM | #104 |
05-03-2012, 02:40 PM | #105 |
Hi Kane,
I love the truck! your truck is doing what my car did. I would adj. the idle air screw and nothing would change at all. I discovered that the throttle hsaft was worn and decided to put in an oversized shaft. So I ordered one only to find out that I already had one in the carb. The replacement shaft would not let me adj. the carb correctly as the screw plate had the incorrect angles-gone. I also sealed up the inside hole (against the engine) where the shaft goes with JB Weld and put some thick grease around the throttle shaft on the outer side. She quit sucking air around the shaft and idles much better now. Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
05-03-2012, 03:16 PM | #106 |
Email me and I would be pleased to provide some names and phone numbers. [email protected] Good Luck ! |
05-03-2012, 03:28 PM | #107 |
Vancouver Island and Vancouver BC are separated by a body of water. You have to take a ferry to get from one to the other. That doesn't mean there aren't any on the island though. Try looking for someone in Victoria BC.
05-03-2012, 03:39 PM | #108 |
I have my connections, one of which lives right in my town and pretty much knows all about A's. I actually enjoy getting feedback on this forum from all you experienced cats and often like to work quietly alone in my shop, if that makes any sense. Plus the more people I get info from, the more I learn. I always want to learn something new. Lastly I thought it would be nice to get on here and say hello now that I own a stock AA...........Hey isn't this sort of stuff what this forum is all about? Appreciate the help on finding local model A guys too, don't get me wrong. Thanks again guys!!!
05-03-2012, 04:58 PM | #109 | |
05-03-2012, 05:51 PM | #110 |
I think the gas gage and mileage is the real prob.... Are the plugs still looking black?. Maybe when the carb was rebuilt, someone left a jet out or somthing......
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
05-03-2012, 06:02 PM | #111 |
I agree. Waiting on plugs in mail, so not changed yet. I'm half ways thinking of just ordering a new carb from Macs or Bratton's or sum thin to just to know all is new and proper. Never been the slickest with carb rebuilds or anything to do with the damn things. Could take it off and apart I guess and try to troubleshoot but.........
05-03-2012, 06:07 PM | #112 |
Kane, I am in Nanaimo and have some extra bits and pieces if there's anything that you may need help with, just send me a pm, I am on the AA site also.
Did you find your truck locally? It looks to be in great shape. There are only a handful of running AAs on the island that I know of, one similar to yours in Saanich. |
05-03-2012, 06:12 PM | #113 | |
05-03-2012, 06:41 PM | #114 |
The carbs are easy to work on and simple. I think I would play with GAV and run a little lean or when the RPM goes high. Then adjust the idling screw when the idle is too high. The idle screw is on the throttle linkage. Make sure you throttle lever is all the way up when playing with the idle screw. Do not be afraid to take the carb apart. They are pretty simple. The biggest problem I have had is the rust from the gas tank plugging up the sediment bowl and the little screen in the carburetor. I bought a stand pipe filter from one of the parts places. The stand pipe slips into the shut off valve in the tank and keeps the sediment in the tank. I also run a see through inline filter between the tank shut off valve and the sediment bowl. I still get rust after ten years.
Get a can of carb cleaner at Walmart- It Is cheap and good-High tech is their trade mark name. Other carb cleaners are good and wear glasses- you never know what little hole that stuff will blow out. There might be a plug on the bottom of the carb and I would take that out first. Water is heavier than gas and It might have some moisture in the bowl. It will take some tinkering so do not get discouraged. I do not think you will get much more than 30 mph. The black plugs and poor mileage kind of indicate a rich mixture. The gas gauges are kind of on again and off again.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
05-03-2012, 08:04 PM | #115 | |
No affiliation, just a happy customer. |
05-03-2012, 09:00 PM | #116 |
So my wife tells me about this application you can get on your iPhone. A speedometer. She says it works exactly accurate. I'm like ya right...... So I try it. I turn it on and go for a drive in our brand new mini van (don't tell anybody I have one of those), and it id dead accurate!!! So I thought I'll try it in the Model AA. Turns out my speedometer is out to lunch. When it reads 35 MPH I'm actually going 50MPH. So I must have the high geared diff. I thought I was going faster than it read. Why is it out by 15MPH. Again running 6.50x20 all the round. As odd as that is this is good news, plenty of speed for me!!! Still chugs gas though, and I'm pretty sure the gas gauge is ok, but.........
05-03-2012, 09:18 PM | #117 |
If I remember correctly there were a few posts quite a while ago about improper length air adj screws?? I mention this as you say adjusting yours doesn't make much of a difference. Congrats on traveling 50MPH. That is a very nice looking truck.
Paul in CT |
05-03-2012, 10:04 PM | #118 |
"Still chugs gas though, and I'm pretty sure the gas gauge is ok, but......... "
You need to slow down! |
05-03-2012, 10:27 PM | #119 |
Some air adj screws are two short & the spring will get coil bound before the screw is seated & you will not be able to get a proper idle mixture adj.If the screw is lightly seated & there is still space between the coils,then the screw length is OK. As for clubs,there is a model A & B club in Nanaimo & the VCCC(vintage car club of canada)has chapters inCowichan valley,Nanaimo,North island& Victoria.
05-04-2012, 07:49 PM | #120 |
Read 119 post to find out the speedometer was bad, you need to make this a TV show, great story, keep it up
