05-09-2012, 06:24 AM | #21 |
Re: 1929 Ford Coupe - Rusty to Solid
I really enjoy seeing the results of your work. It is amazing!
05-09-2012, 08:58 PM | #22 |
thanks Country!1
finished up the drivers side bracket this morning thats they dont repop then set the seat pan in transferred the rivet holes and got everything lined up there. the rivets arnt set just keeping the panel aligned . i didnt put the rear pan in because it will be much easier to work on the rear of the car with out that piece in. moving back ward to where the new subframe was once welded on . it needed some help in my opinion a few patches later and a little tig welding its looking a little better and the connection on the drivers side after got all the welds smoothed out
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 05-10-2012 at 07:21 AM. |
05-09-2012, 09:25 PM | #23 |
Flop, you are an artist with some mad skills! Keep up the amazing work.
05-10-2012, 10:23 AM | #24 |
This is an amazing thread to follow! You should think about putting this all together and getting it published! Thanks for taking the time to do this.
05-10-2012, 03:06 PM | #25 |
thanks seth !!
just another days work 28annie! but i do like taking the time to show folks what goes into bringing a car back the correct way . this was a random hole cut here where there was a body mount had to patch it before i put the subframe in the subframe was cut to close to the brace so i couldnt clean up the weld nicely. so i cut out some of the new subframe so i could achieve that and the new connection
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 06-20-2012 at 06:12 AM. |
05-10-2012, 09:04 PM | #26 |
Respecting and Resurrecting Ford Model A's. |
05-11-2012, 05:33 AM | #27 |
Just love the progress photos, please keep them coming.
Adjust your points with gentle blows of a 2 pound hammer |
05-11-2012, 07:51 AM | #28 |
Great work Flop and the owner has got to be loving this, almost as good as watching over your shoulder! Keep the updates coming! Dale
05-11-2012, 07:50 PM | #29 |
Hey flop Im going through the same thing on my 29 truck, first time on restoring one. Any hints on doing the sub rails and could u fab. up a set of door post connectors for me? Restoring my grandfathers truck witch he handed down to me was I was about five now Im 45 and just getting started, would mean alot to me with alittle help in the right direction Thanks Pete
05-14-2012, 08:47 PM | #30 |
thanks everyone!!
Vanspeed i never really use a dremel . i grind with a 36 grit 6 inch disc on an electric sander . i also use 60 grit on a 3 inch roloc and a file. 29 -make sure you are working off a frame that is level and square .ill send you a message about the connectors
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom |
05-15-2012, 09:41 PM | #31 |
Thank flop I did learn alot off this forum, I will be calling thanks again Pete
05-17-2012, 08:59 PM | #32 |
did some more work on Miles coupe today
put a patch in this riser .no sense on getting a repop when only 1 tiny section was rotted out got it all smoothed out this piece in my opinion this rear panel below the decklid is the biggest pain to get out of an A after i got it out had to redrill and tap all 8 screw holes in the rear subrail
05-18-2012, 04:03 PM | #33 |
Excellent work, Flop! I am getting closer to taking my 29 apart to check just how solid it really is, so this thread is extremely helpful to me in case mine isn't as solid as it was reported.
Subscribed, and ready for your next posts!! |
05-18-2012, 08:25 PM | #34 |
thanks co29 1 glad to know people can check on the thread and get some help from it!!
didnt get much done today juggling a bunch of projects at the moment but i did get this area cleaned up and for the most part have 90 percent of all the subframe work done and riveted back in after i patched it
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 07-28-2012 at 08:53 PM. |
05-23-2012, 07:55 PM | #35 |
well up front to a rotten door pillar
a little brace so i can fix the bracing bent this up made the step with a bead roller and all welded up ready to get covered in sheet metal!!
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 06-20-2012 at 06:13 AM. |
05-29-2012, 08:04 PM | #36 |
well got the quarter patched and the wheel well a quarter of the way in
i also wonder why they make the patches so horrible ? i mean come on almost a quarter inch short isnt from die wear!!
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 06-20-2012 at 06:14 AM. |
05-30-2012, 01:31 AM | #37 |
Are all the patches 1/4 inch short?
05-30-2012, 08:22 AM | #38 |
Been enjoying the posting a lot,thanks,i'm sub. to thread.
05-30-2012, 10:02 PM | #39 |
no idea if all patches are short but every patch needs messed with in some wya or the other
thanks dana ! got the quarter squared away today and heres a few holes of what was left after the patch was in and this is it all finished up
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 07-28-2012 at 08:54 PM. |
06-19-2012, 09:12 PM | #40 |
well took a run to snyders today picked up the rear patch for Mile's coupe as well as a truck full of other things
heres the problem . which in-turn sucked in the trunk gap a little brass and a double panel!! tacked in about 75% done no real complaints with the panel either a little tweaking here and there but no major surgery to it yet !
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 07-28-2012 at 08:55 PM. |
