01-04-2012, 04:06 PM | #1 |
fuel line
What type of sealant do i put on the threads to the fitting that goes to into the fuel thank?
Thanks |
01-04-2012, 04:33 PM | #2 |
Re: fuel line
NONE. The ferule on the end of the line is squeezed by the nut. That is what seals it. G.M.
www.fordcollector.com |
01-04-2012, 04:42 PM | #3 |
Re: fuel line
I think he means the threads going in the tank, I just use a good pipe dope for liquid fuel.
01-04-2012, 08:04 PM | #4 |
Re: fuel line
That is what i meant Sonny, thanks for the back up.
01-04-2012, 09:12 PM | #5 |
Re: fuel line
like gm said none. the sealing takes place with the ferule. the fiting threads hold the ferule in place . same thing goes for flared lines
01-04-2012, 09:46 PM | #6 |
Re: fuel line
01-04-2012, 10:03 PM | #7 |
Re: fuel line
This is not a pipe fitting, it is a nut and ferrule. You could put some pipe sealant on more as a lubricant but this type fitting is sealed by the ferrule being compressed around the tubeing and against the seat and nut. This is the same fitting as on both ends of the fuel line between the fuel pump and carb. G.M.
01-04-2012, 10:05 PM | #8 |
Re: fuel line
The threads aren't supposed to seal.
Bill |
01-05-2012, 12:00 AM | #9 |
Re: fuel line
If you want a worry free seal it wont hurt to apply a coating of LOCTITE 567 to all your fuel fittings and threads, tighten remove excess and allow 24 hours to dry or may be any other suitable Anerobic Sealer, works well on my vehicles.
01-05-2012, 07:38 AM | #10 |
Re: fuel line
G.M. and Richard crow I think you didn't understand the question. Read it again and look at some of the answers. Were not talking about the ferrule.
01-05-2012, 08:31 AM | #11 |
Re: fuel line
Read my post you don't seem to understand how the fitting at the pick up tube going into the tank works. G.M.
01-05-2012, 09:19 AM | #12 |
Re: fuel line
01-05-2012, 10:40 AM | #13 |
Re: fuel line
I agree with GM and Kube. No sealant is necessary or desired. The fitting threads should be clean and the end of the fitting should tighten against the ferrule to seal the fuel. The ferrule should be soldered to the line.
TomO |
01-05-2012, 10:43 AM | #14 |
Re: fuel line
Lots of useful info here . If you are talking about a 33-34 passenger car here all you have is the plug on the bottom { pipe thread } & the pickup-sending unit & that has a gasket that takes care of that . The gas & air lines as stated above do not require any sealant . It would be helpful if you at least tell the troops what your working on .
Last edited by David J; 01-05-2012 at 10:04 PM. Reason: BAD SPELEN & thanks to Old Henry fix a boo-boo |
01-05-2012, 11:29 AM | #15 |
Re: fuel line
Yes...there are no clues as to car under discussion. I believe answers will differ if post-1948, if early Ford I believe all use the compression ferrule and if gas gets to the threads you have a failure needing repair, not a need for goo!
01-05-2012, 11:45 AM | #16 |
Re: fuel line
1940 ford
01-05-2012, 12:26 PM | #17 |
Re: fuel line
White teflon tape is for water and air line installations only. Yellow teflon tape for natural gas/propane. All teflon tape is deteriorated by gasoline and shouldn't be used for gasoline or other petroleum product fittings.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
01-05-2012, 12:31 PM | #18 |
Re: fuel line
The one I am referring to is a 32bb tank. The shutoff valve screws into the tank ( dope is optional ). Then you install your fuel line, with ferrule and nut. No dope is necessary.
01-05-2012, 12:46 PM | #19 |
Re: fuel line
I have used Stainless Steel pipe Sealant as it is not affected by gasoline and will keep the threads lubricated.
Any man who thinks he can be happy and prosperous by letting the Government take care of him, better take a closer look at the American Indian!" - Henry Ford Last edited by Dave Mc; 01-05-2012 at 02:00 PM. Reason: more info |
01-05-2012, 01:23 PM | #20 |
Re: fuel line
What part of "none" don't you understand? Any kind of sealant WILL NOT help with gas leak on these type fittings and may well make removing difficult. As mentioned by others the threads are not the sealing, the ferrule is.
