12-13-2011, 10:20 PM | #21 |
Re: Dropping rear axle: Rear spring
Now I'm really confused. Just about as many say "leave the spring on the axle" as do say "leave the spring attached to the frame". And then to add insult to injury, there's the comment "to leave the spring on the axle, but use a good spring spreader." I wouldn't think that a spring spreader would be necessary if you left the spring on the axle.
12-13-2011, 10:43 PM | #22 |
I agree with Tom Endy's advice above. Any one who trusts their fate to that center spring bolt not breaking while the spring is out of the rear cross member is a fool. When I assemble or disassemble the rear spring leaves i always wrap a heavy chain, ends bolted together tightly, around the spring before tightening or loosen the center bolt and leave the chain on the spring while handling it and remove the chain only when it is being put into the cross member. Think "giant cross bow" ready to fire at any unknown moment.....safety first !
Leave the spring in the car and undo the shackles to drop the rear. Much safer. |
12-13-2011, 11:04 PM | #23 |
I bought my spring spreader from AC&R a number of years ago. It was about $60 then. It was made by Pete Weschler the original owner. He still makes them for other suppliers. The one I have is a bare bones model. Bratton carries a similar one with more bells and whistles, such as thrust bearings, spring loaded feet, and feet retainers. They sell for about $135. If I was buying a new one I wouild get the bell and whistles one as it is easier to use and I use it a lot.
I think Snyders carries the bare bones one for around $85. Either one is a proper spring spreader and is safe to use. CarlG: When you enncounter a rear axle assembly that someone has removed from the car with the spring still attached, you will still need the spreader to get the spring off if you want to dissemble the rear axle assembly. Tom Endy |
12-13-2011, 11:13 PM | #24 |
Tom,
The MAIN leaf of the rear spring is energized....when spread and fastened to the spring shackles no? As long as the shackles/ bolts/bushings are good shape, I'm trying to understand how the 'danger' occurrs when leaving the spring attached and removed with the rear axle ? I can understand and see the danger of working with defective/faulty/worn out parts and / or using dangerous methods...such as using a home made spreader that collapses/bends and/or slips and suddenly releases the spring. But , if you KNOW that you're working with good parts , wouldn't it be SAFE to leave the spring on the axle to remove it ? Last edited by hardtimes; 12-13-2011 at 11:15 PM. Reason: add.. |
12-13-2011, 11:16 PM | #25 |
I use the newer Brattons spreader. The thrust washers make turning it easier than the style without them. I agree with Tom about leaving the spring safely locked in the cross member and restrained by a spreader. I have seen springs let go. I have seen shackles break under tension. They make me nervous as heck when they're un clamped.
12-13-2011, 11:19 PM | #26 |
12-13-2011, 11:56 PM | #27 | |
12-14-2011, 12:50 AM | #28 |
12-14-2011, 12:55 AM | #29 |
I remiove the body, engine, tranny and front axle of this wreck first. I was down to the rear axle and frame and when I was removing the rear spring U bolts I thought it was strange that they seemed to have pressure all the way to the end. It never dawned on me that the center bolt for the spring was rusted and no longer holding. When I got to the last thread of the second U bolt the frame suddenly jumped into the air a couple feet. Luckily I had my chest and head just behind the rear crossmember, but that taught me a lesson. I didn't have my spring spreader at the farm where this wreck was taken apart and I should have waited until I had it. |
12-14-2011, 10:15 AM | #30 | |
The drive shaft can be pulled out of the banjo housing without disassembling the rear end banjo. You pull the pinion bearings and race out as one assembly, attached to the drive shaft. Then you tap the new shortened drive shaft back into the banjo, all while not removing the spring.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
12-14-2011, 02:26 PM | #31 |
12-14-2011, 02:40 PM | #32 |
What it really boils down to is that EITHER the rear axle gets dropped, OR the engine/tranny gets pulled. Can't do it without one or the other.
12-14-2011, 04:02 PM | #33 |
CarlG: If we're after the rear spring, why would we pull the engine and tranny??
Paul in CT |
12-14-2011, 04:16 PM | #34 |
Sorry, somehow this thread morfed into pulling the drive shaft / pinion out of the banjo. I guess that's what I was referring to.
12-14-2011, 06:09 PM | #35 |
Sorry CarlG, I'm the cause of the drive shaft discussion. Here was my thought, first off I forgot about the special tool that can be used to pull the driveshaft, pinion, bearings and race all at the same time ,out the front of the banjo. I was pretty sure that the drive shaft would have to be removed and shortened. The way that I have removed model A driveshafts over the years ,without this sometimes flimsey tool, has been to remove the left rear end houseing, differential and remove the driveshaft and pinion from the rear. If this procedure was used it would be just as well to leave the spring mounted to the frame because it would need to be removed anyway. Otherwise I always remove the backend with the spring attached. Rear springs can be dangerious and if I was working on one that looked like the ones that Tom Wesenberg or Leatherneck described, I would be cautious. I have several used spring assemblys in my parts collection, I'm sure others do also. I see them at swap meets often. I wouldn't even mention the spring issue but a couple of guys make it sound like the very sight of a used spring pack was time to call the bomb squad. One even as much as called anybody that removed the backend with the spring attached was a FOOL. I would never tell anybody what they should do. I only say what I would do or have done . I never said anything about touching the spring center bolt.
12-14-2011, 06:11 PM | #36 |
This is the tool you need to pull the drive shaft and pinion assembly out of the banjo without disassembling the rear axle assembly. You don't want to loosen the two large nuts on the pinion if you want to retain the pre-load.
Tom Endy |
12-14-2011, 06:44 PM | #37 |
Is that the tool that Mitchell makes?
12-14-2011, 07:04 PM | #38 |
CarlG:
No, it is the one I had made. Mitchell does make a similar tool, but I believe you have to remove the two large nuts to use it. You will then have to re-set the pre-load on the pinion once you install the new shaft. You will also need some kind of a pusher-back-in tool to get the pinion back in the banjo. Tom Endy |
12-14-2011, 07:07 PM | #39 |
Looks like I have a whole bunch of homework ahead of me before I get my OD installed this winter.
12-14-2011, 07:34 PM | #40 |
Carl, what I did was removed all the stock parts from the car that I wasn't using, and put them in storage. I picked up another rear end, and rebuilt it to my needs. I don't know how plentiful parts are up there in Alaska. If not changing your truck back to stock, then you would have a complete set up for your next project. There's always one more, right?
