Old 05-16-2011, 07:17 PM   #61
pat in Santa Cruz
pat in Santa Cruz's Avatar
Default Re: Vibration
[/QUOTE] ...Buy the way, removing that org. frt. motor mount by just jacking up the frt. of the eng. and removing the two bolts from the eng. and the one underside is impossible [for me anyway]. [/QUOTE]
remove one rear motor mount to flywheel housing bolt from each side, then you can jack the engine high enough to clear the pulley with the front yoke. not removing the two rear bolts can crack the flywheel housing if you lift the front of the engine much.
Unless your car is a fine point Nov 28 thru Jan 29, replacing the brass washer with3/16ths flat washer might improve it a bit more. That's what Henry did.
pat in Santa Cruz is offline   Reply With Quote
Old 05-16-2011, 07:21 PM   #62
RHD
RHD's Avatar
I have just posted this as below, but it did not appear. Here goes again.
I fitted counterweights to my 30 Phaeton's crankshaft and it was as smooth as silk. The engine, clutch, crankshaft and flywheel were balanced by the engine reconditioner. I installed at the time new rear engine mounts with fresh live rubber. (A repro set.) A lot of vibration can come through the rear mounts as previously said. Fan blade was a new Al repro. I know some engine reconditioners don't take much care with a Model 'A' block as they should do, especially when they know it is not going to travel very fast. Many engines could be balanced a lot better with a little more care and consideration by the engine shop. They all charge enough.
R.H.D.
Author of Model 'A' Ford technical manuals.
Supplier of good original RHD parts.
RHD is offline   Reply With Quote
Old 05-16-2011, 08:30 PM   #63
Louis
Unless your car is a fine point Nov 28 thru Jan 29, replacing the brass washer with3/16ths flat washer might improve it a bit more. That's what Henry did.[/QUOTE]
Pat,are you saying a 3/16ths flat washer would be better then the brass frt. eng. support bushing ?..Is that because it is thiner and would give you more spring on the top two mount springs ?
Louis is offline   Reply With Quote
Old 05-16-2011, 08:35 PM   #64
pat in Santa Cruz
Pat,are you saying a 3/16ths flat washer would be better then the brass frt. eng. support bushing ?..Is that because it is thiner and would give you more spring on the top two mount springs ?[/QUOTE]
the bushing fits tight into the cross member hole, somewhat restricting side movement. A flat washer allows that movement without allowing the mount shaft vibrations to be transferred to the cross member through the bushing. I have never tried to compare the two. I just use what Henry did on the appropriate year car. It would be interesting to see if you switch them and find any difference.
Old 05-16-2011, 08:57 PM   #65
Louis
the bushing fits tight into the cross member hole, somewhat restricting side movement. A flat washer allows that movement without allowing the mount shaft vibrations to be transferred to the cross member through the bushing. I have never tried to compare the two. I just use what Henry did on the appropriate year car. It would be interesting to see if you switch them and find any difference.[/QUOTE]
I might try that later, but I am so pleased with the lower vib. I think I will drive it for a few days, And then try it.
It seems like if you allow the mount shaft to have side movement that the movement might cut into the shaft it's self over time, I don't know?
Any way right now, Im a happy guy .
Old 05-16-2011, 10:01 PM   #66
pat in Santa Cruz
it does not move sideways enough to cut into the shaft, although I have seen some on warped frames that did that. Henry tried that brass bushing for only 2 months then quit for some reason. I assume it was a good one, but it could just have been costs saving. He was a cheap one.
Old 05-17-2011, 05:03 AM   #67
James Rogers
James Rogers's Avatar
Try the brass bushing but just flip it over so the smooth side is against the frame. A little grease will help.
