Old 09-19-2020, 09:50 AM   #1
nascar88in02
nascar88in02's Avatar
Default generators
Can a long shaft generator be replaced with a short shaft? If so what all needs changed?
nascar88in02 is offline   Reply With Quote
Old 09-19-2020, 10:39 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: generators
all the 28-34 four cylinder generators will interchange as complete assembly
to use long taper shaft with short taper pulley you need a spacer, to use long taper pulley on short taper generator it takes a longer bolt
It's all in the service bulletins, page 447-448
Old 09-19-2020, 11:35 AM   #3
Purdy Swoft
Purdy Swoft's Avatar
Unmodified model A generators will charge a twelve volt battery . The model A generator doesn't put out as high of amperage as the alternator . The lights won't be as bright but will otherwise work on a twelve volt system .
Old 09-19-2020, 12:41 PM   #4
nascar88in02
Everything is still 6 volt, Someone put a 6v alternator on it and I want to put it back more factory.
Old 09-19-2020, 02:12 PM   #5
Purdy Swoft
You can just bolt on a model A generator and cut out and that should do it . A Fun Projects voltage regulator can replace the cut out and give similar voltage regulation as later model cars . I use one on my model A and it looks just like the cut out .
