Old 07-31-2019, 08:30 AM   #1
Baypac
Baypac's Avatar
Default Drag Link to Pitman Grease Seal 1930 Sport Coupe
Finished installing a new shortened Pitman arm and decided to replace the rubber grease seal. Once all was back together, there is significant space at the rear end of the seal and the drag link opening. Is this normal or was there a different seal originally.
Baypac is offline   Reply With Quote
Old 07-31-2019, 12:32 PM   #2
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
Default Re: Drag Link to Pitman Grease Seal 1930 Sport Coupe
Try rotating the rubber seal 180 degrees.
MickeyT is offline   Reply With Quote
Old 07-31-2019, 02:45 PM   #3
Cave
Cave's Avatar
This is from a guy who marched in cadence "go to my right, my left, my right" until all the pushups straightened me out... but I think Mickey meant 90 degrees.
Cave Luther
Syracuse, NY
1931 Deluxe Coupe (Rose)
______________________________________
"... I'm pullin' for ya, we're all in this together." Red Green
Cave is offline   Reply With Quote
Old 08-02-2019, 11:06 AM   #4
redmodelt
redmodelt's Avatar
No it would be 180. Because of how they are made, being cupped they can really only go on two ways. The seal HELPS keep the dust, dirt and water out but it's not perfect. Keep it well greased and the grease will act like a barrier. When greasing, pump more then is needed and wipe off the excess, that will help flush out the dirt.
https://www.snydersantiqueauto.com/P...earchByKeyword
Old 08-03-2019, 08:46 AM   #5
john in illinois
john in illinois's Avatar
Did you also instal the steel backer for the rubber seal? Mine usually fit ok with no gap, but reproduction one sometimes are hard to fit.
John
Welcome each day
john in illinois is offline   Reply With Quote
