12-16-2010, 12:57 PM | #21 | |
Re: Rear spring spreader
pooch I measured the spring in post 10 and the distance c to c was 40" (spring eye to spring eye). This spring is from a 29 roadster pickup.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
12-16-2010, 01:43 PM | #22 |
Sturgis, ..40 inches, when it becomes dawn, I will measure my in car spring and check against Tom's figures and save post in my Model A folder for if or when I need to remove spring.
thanks. |
12-16-2010, 05:35 PM | #23 |
Here's a picture of the complete spring spreader I made. Sometime I plan to use a screen door spring inside the square tubing to hold the two threaded rods in place. In the meantime I'll just use a bungee cord. Last edited by Tom Wesenberg; 11-05-2011 at 01:00 AM. |
12-16-2010, 06:00 PM | #24 | ||
design tensile strength= 20.7 kips design shear strength= 11.0 kips (where kips is 1000 pounds) Quote:
What I did was not use a spreader at all. I took the pack apart. Installed just the mainleaf with the shackles, then installed all the component leaves with 2-6" C-clamps. |
12-16-2010, 06:14 PM | #25 |
ditto: but without c-clamps if my memory works. I must have been lucky back in the 60's. Always had either front or rear end out, 32 coupe, olds eng. Trying to make the "rake better.600/15-820/15, then a 3" block on top of rear spring. Then a few leaves out of front spring. Then the trend was to "gasser: look, add a block to front on top of spring, longer shackles (they didn't work). Never gave a thought to spring "exploding.
Paul in CT |
12-16-2010, 11:10 PM | #26 |
So, If I allowed for 1 inch out either side and 3 1/2 inches in each side to release, that would make 4 1/2 inches of thread each side. Does this sound right? (49 to 40 inches total). |
12-17-2010, 12:11 AM | #27 |
I have my coupe torn apart for restoration and am currently working on the rearend. I have 10 springs that in the relaxed position is 15 1/2 inches tall to the bottom of the stack, it is 40 inches from center of bolt hole to center of bolt hole.
12-17-2010, 03:21 PM | #28 |
You should make the spring compressor to collapse down to 38", or you may have to work some to get the spring off. And nobody likes work!
12-17-2010, 03:28 PM | #29 |
OK, 49 to 38 it is.
12-18-2010, 01:44 PM | #30 |
I followed the instructions as per: http://www.icehouse.net/overland/springspreader.html and it worked perfectly, plenty of grease to lubricate the moving sections.
02-05-2011, 02:35 PM | #31 |
btt
02-06-2011, 02:24 AM | #32 |
btt
02-14-2011, 12:13 PM | #33 | |
02-14-2011, 12:55 PM | #34 |
The Restorer club magazine Vol 23-4 Nov. Dec. 1978 has an excellent article on how to build a rear spring spreader. I built one and it is a real good one. Email me and I can send pictures and the plans. [email protected] Dick Hansen
02-14-2011, 08:06 PM | #35 |
Just measured a spare 8 leaf rear spring.It is 41 1/4" center to center Hope this helps
02-14-2011, 09:35 PM | #36 |
Wonder how many aftermarket spreaders were available. Mine was made by ARPS Corporation of Snowbird fame. I have seen another like it.
04-07-2011, 01:55 AM | #37 |
btt
04-07-2011, 07:45 AM | #38 | |
Terry |
04-07-2011, 08:11 AM | #39 |
btt
06-24-2011, 09:51 PM | #40 |
byy for a v/8 guy
Thread Tools | |
Display Modes | |
