Old 08-31-2016, 06:14 PM   #1
Bob Grieb
Bob Grieb's Avatar
Send a message via Yahoo to Bob Grieb
Default Question Regarding Shortened Emergency Brake Handle
I am helping a friend install an air conditioner in his Model A and the emergency brake handle interferes with the evaporator handle. Does anyone know if you can purchase a shortened brake handle?
Thanks for your help.
Bob
1929 Tudor
1930 Pickup
Bob Grieb is offline   Reply With Quote
Old 08-31-2016, 07:49 PM   #2
tbirdtbird
Default Re: Question Regarding Shortened Emergency Brake Handle
Hmmmm....
if this is a Ken Davis kit, he supplies a special bracket that tilts the ebrake handle back some to clear the evap.
I know of no one else supplying such kits.
You would have a dickens of a time setting an ebrake with a shortened handle
'31 180A
tbirdtbird is offline   Reply With Quote
Old 08-31-2016, 08:44 PM   #3
Bob Grieb
Bob Grieb's Avatar
This is a Ken Davis kit and the installation has gone well. I am aware of the bracket you speak of and it was in the kit. What I did not mention is the his Model A has a transmission out of a 50's Ford Pickup and the bracket included in the kit will not work as furnished. I was hoping that we might find a source for a shortened brake handle. It would only need to be an inch shorter to clear the evaporator housing.
Thanks for your input.
Bob
1929 Tudor
1930 Pickup
Old 08-31-2016, 08:58 PM   #4
tbirdtbird
Ken is familiar with that tranny setup, a lot of Dallas members have it. He prolly has a workaround for you. I would contact him directly; he tries hard to be helpful. If you have the kit then you have his contact info.
here is his website with contact info
http://www.kendavismodela.com/index.html
'31 180A
Old 08-31-2016, 09:07 PM   #5
MAG
MAG's Avatar
I shortened the Ebrake handle 3 1/4".. Works fine.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 08-31-2016, 09:14 PM   #6
Bob Grieb
Bob Grieb's Avatar
Did you do the work yourself or have it done
1929 Tudor
1930 Pickup
Old 08-31-2016, 10:01 PM   #7
Gary/IA
Gary/IA's Avatar
I purchased a repo brake lever and cut it down enough to clear. I cut it down and a friend with a welder welded it for me. The weld is covered by the rubber boot. It works very well.
Gary/IA is offline   Reply With Quote
Old 08-31-2016, 10:11 PM   #8
700rpm
700rpm's Avatar
Wwhd?
Ray Horton, Portland, OR
Old 08-31-2016, 10:12 PM   #9
MAG
MAG's Avatar
I cut a 3 1/4" section from the lower end of the handle and welded the handle in place.
Cut the same amount from top of the rod, drilled a new hole for the pin holding the button on. Reassembled and installed.
This is on a F150 transmission. Amount to remove might vary slightly on Model A transmission. Measure first.
Old 08-31-2016, 10:48 PM   #10
CWPASADENA
CWPASADENA's Avatar
Bob
The '32 hand brake assembly is the same as a Model A except for the ratchet. The '32 ratchet lowers the handle about an inch or may be even a little more.
You will have to be a little more specific about the transmission. If it is a later top shifter type, the Early V-8 Garage in West Covina, Ca. (626) 338-2282 makes a bracket that bolts to the transmission. The hand brake assembly will bolt to that bracket.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 09-01-2016, 12:09 AM   #11
Bob Grieb
Bob Grieb's Avatar
Thanks for all the responses. I will make some calls in the morning.
1929 Tudor
1930 Pickup
Old 09-01-2016, 08:25 AM   #12
JohnLaVoy
JohnLaVoy's Avatar
Speedway sells a short emergency brake handle.
JohnLaVoy is offline   Reply With Quote
Old 09-01-2016, 08:41 AM   #13
Bob Grieb
Bob Grieb's Avatar
Thanks John
1929 Tudor
1930 Pickup
Old 09-02-2016, 01:07 PM   #14
Bob Grieb
Bob Grieb's Avatar
I appreciate all the input/help. I finally modified the furnished bracket and made connecting brackets and it works well.'
Thanks
Bob
http://www.fordbarn.com/forum/album.php?albumid=4251
1929 Tudor
1930 Pickup
Old 09-02-2016, 01:08 PM   #15
Bob Grieb
Bob Grieb's Avatar
1929 Tudor
1930 Pickup
Old 09-02-2016, 01:10 PM   #16
Bob Grieb
Bob Grieb's Avatar
I could not figure out how to upload the picturehttp://www.fordbarn.com/forum/album.php?albumid=4251 but I did upload the URL
1929 Tudor
1930 Pickup
Thread Tools
Display Modes
