02-24-2016, 01:38 PM | #1 |
Door Handle Removal 52 Merc
Looks like the inside door handles need to come off if I am going to get access to work on the window mechanism that won't wind down. I can't see how the inner door handle and window crank come off. Any advice out there?
https://www.youtube.com/user/roosty6/videos |
02-24-2016, 01:50 PM | #2 |
Re: Door Handle Removal 52 Merc
If it's anything like a contemporary Ford, the handles are held on by what we used to call "Jesus Christ" clips from the magic words sometimes required to get them off. There are a couple of special tools used to remove them. The first type is kinda' like a specialized pliers (which I never had much luck with), while the second is a kind of sheet metal plate with a specialized notch in the end that you push behind the door handle that spread the clips and pushes them off. I had better luck with these, except for one I bought that was too thick to fit in the slots in the handles. Get the thinnest one you can get. The last time I needed one, I found it on the "Help!" rack at NAPA.
02-24-2016, 01:58 PM | #3 | |
Sometimes a metal dental pick with an "L" end can get 'em if you approach from the correct side. |
02-24-2016, 02:16 PM | #4 |
These are the two different tools for removal of the spring clips
You could make up a tool out of a hacksaw blade with a hook to catch the open end tang and pull it out.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 02-24-2016 at 02:30 PM. |
02-24-2016, 02:23 PM | #5 |
Thanks for all the info so far. I will have another look later today or tomorrow but I don't recall there being any space between the back side of the handle and the door panel.
02-24-2016, 02:28 PM | #6 |
02-24-2016, 04:25 PM | #7 |
I have also heard you can wrap a rag around the shaft under the flange and if done right, it'll catch the end of the clip and pop it off. I personally have never had any luck doing it that way, but what's the harm in trying?
02-24-2016, 06:58 PM | #8 |
I have to use the plier types as pictured in one of the previous photos for my 1951 cars and the 1952 uses the same handles. It's just the way the handles were made. One tool can push the clip out on many different handles but some, like those Mercs, have to be pulled out from the other side.
