06-16-2015, 08:24 AM | #1 |
Crop circle belivers, read this!
If you think Drano poured in a plugged sink will clear drains, or metal mend fixes cracked blocks, or politicians will make our world a better place.
Then a flush of vinegar in your radiator will clean out 80 years of grease and rust and mineral scale. |
06-16-2015, 09:21 AM | #2 |
Re: Crop circle belivers, read this!
I am not sure what your message is ?? Wayne
06-16-2015, 09:36 AM | #3 |
Sounds like ya got an overheating problem huh?
06-16-2015, 09:59 AM | #4 |
06-16-2015, 10:17 AM | #5 |
I think he is saying it works great!
06-16-2015, 10:19 AM | #6 |
Terry |
06-16-2015, 11:00 AM | #7 |
I thought you were going to tell us crop circles were casued by Model A's doing donuts in the field.
If the radiator tubes are plugged solid, then nothing short of removing the tanks and rodding it out will work. Of course I have seen those little gremlins on TV that chomp away on grease and dirt in the drain, so maybe they will eat the junk in the Model A radiator. |
06-16-2015, 11:15 AM | #8 |
Crop circles=Model A's doing donuts...priceless imaging.
06-16-2015, 11:42 AM | #9 | |
06-16-2015, 11:53 AM | #10 |
Sorry, I'll try it again, shortcuts don't work.
06-16-2015, 12:11 PM | #11 |
06-16-2015, 12:21 PM | #12 |
two different interpretations for sure. Now we await his response ! Wayne
P.s. Thanks Blue Sunoco ! |
06-16-2015, 12:44 PM | #13 |
I think his high speed muffler bearings are running lean.
Just My W.A.G. Jerry |
06-17-2015, 05:39 AM | #14 |
Sounds like Tim is having a bad day.
06-17-2015, 06:51 AM | #15 |
tim your correct it usually will cause a whole slew of other issues on an old cooling system...
its sorta like peeing in the wind or eating yellow snow.. the best ones are where no problem exsists and someone feels preventative maintenance is in order... the most i would do on an old system that is not running hot is drain, refill and not break loose internal garbage with cleaning agents... |
06-17-2015, 12:15 PM | #16 | |
Look at IT another way, i.e.- it radiator tubes have 'scale/rust' to the point of impairing its' primary function.....where is all that scale, etc coming from ! I'd think to remove the source of the contamination (block/head) and work forward to how bad of a radiator condition exists. A newly cored radiator can get plugged tubes from a crud filled/rusted head/block. If a bandaid approach is used first/only (vinegar)..then ?? |
06-17-2015, 12:22 PM | #17 |
I bought a new radiator but sure didn't want to install it only to have it clog with rust and scale out of the engine. I removed the head and used some metal rods to clean out the engine passages.
06-17-2015, 12:36 PM | #18 | |
Guess what I'm asking is...was it worth taking the engine half apart? And what were your results afterwards? Do you have any pics of that dirty deed?
06-17-2015, 12:40 PM | #19 | |
beats clogging a 700 new rad and ending up with the same issue |
06-17-2015, 03:12 PM | #20 | |
That's what I'm talking about , good on you ! This 'hobby' is tooo expensive for most of us, than to throw new stuff at a problem without solving the problem first. I've recently taken huge amounts of rust/scale out of flathead blocks, mainly in and around the REAR cylinders. It this practice is not thought of and/or done, it will let you know sooner than later. |
