11-04-2014, 05:22 PM | #21 |
Re: spark tester for model A
Maytag
11-04-2014, 07:51 PM | #22 | |
My repro ford battery is low " won;t fully charge: powered. I will try it with an Optima battery. What percentage of the cranking power of a battery goes to power the spark plugs rather than just turn the starter? |
11-04-2014, 08:31 PM | #23 | |
If you hand crank the engine you will have the full 6.3 volts to the coil. |
11-04-2014, 09:21 PM | #24 | |
I have an Older Sun Ignition Simulator that goes on the Sun Distributor Testers. Yours is much more compact and just as good. I think I'll make one like yours also. |
11-05-2014, 10:22 AM | #25 |
Try this device
11-05-2014, 11:49 AM | #26 |
The Les Andrews Troubling shooting for model A talks about a Spark plug tester bulb... It looks like a regular light bulb and you hold it to the distributer contacts.....I guess it is a bulb that works with 6 volts. |
11-05-2014, 12:19 PM | #27 |
I haven't seen that, but the ignition secondary is very low amperage and high voltage, but won't light up a 6 volt bulb. It will light a neon bulb however, and I'd guess if you hold one lead of the neon bulb it will light by holding near the plug wires.
11-05-2014, 01:00 PM | #28 | |
I Have Sparks!!!! Happy days are here again! I guess I now have to verify i am getting gas? I have a model B engine and gas pump. |
11-05-2014, 04:22 PM | #29 |
I got then engine running!
Sounds nice and smooth too! Thanks for all your help guys. I could not have done it without your help! |
11-05-2014, 04:28 PM | #30 |
That's great to hear
11-05-2014, 07:18 PM | #31 |
Wow Frank, great news, I've been following your "adventure" here and on the EV8 forum.
Paul |
Thread Tools | |
Display Modes | |
